Old 11-20-2008, 03:17 PM
JamesJ JamesJ is offline
Default Fuel Injector Booties
I was wondering if anyone had a source for fuel injector booties, or what the correct name for them is so that I can look for some. Here is a picture of what I am refering to... Red Witch
James J.
Old 11-20-2008, 03:28 PM
camcojb camcojb is online now
what part of the pic are you referring to? The injector connectors for the wiring?
http://www.fiveomotorsport.com/Injector_CONNECT.asp
Old 11-20-2008, 03:34 PM
I am looking for the rubber boot that covers the pigtail and some of the wires. It may just be some heat shrink, but I was wondering if there was a pre-made one.
James J.
Old 11-20-2008, 03:37 PM
I thought that was heat shrink. I've never seen them before.
Old 11-20-2008, 05:29 PM
clill's Avatar
clill clill is offline
They are cool little booties.....Top secret.....or get them at the little bootie store....Or wait till Stielow gives a better answer...
Old 11-21-2008, 07:09 AM
B Schein's Avatar
B Schein B Schein is offline
Motec
Brian
Old 11-21-2008, 08:30 AM
deuce_454's Avatar
the boots come with the connector if you buy them from bosch... atleast they do around here....
Jake: Hit it.
Old 01-30-2009, 05:04 PM
The T-man The T-man is offline
nice intake
Old 02-01-2009, 11:33 AM
ohcbird's Avatar
ohcbird ohcbird is offline
Default Injector Boot
Those are the Bosch-style long boots. The good news is that they are available at your local Napa, or any Echlin dealer. They are made for the Bosch connector with the hooked lip, but good for us is that 80% of top-feed injectors are setup that way. Even without the lip, the boots still hang on to most injectors. Here's a link to them @ Napa:
http://www.napaonline.com/NOLPPSE/(S...414_0000999999
Old 02-01-2009, 02:17 PM
GeoffP GeoffP is offline
That's a cool little item to know about. I was just going to chime in to say that early tuned port cars had something similar on the harness to cover the injector connector. My IROC had them on the factory harness (87) when I pulled the 305.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
