Old 12-14-2008, 06:26 PM
MAK567's Avatar
MAK567 MAK567 is offline
Default Here Is My Future 87 Gn
Just trying to decide on wheels right now .tubular upper and lower control arm frt and rear afx spindles with c6 brakes on all four corners.
Old 12-14-2008, 10:18 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
I want one of these so bad. The pic is too small once opened.
Old 12-14-2008, 11:10 PM
GvEman's Avatar
GvEman GvEman is offline
Wow!! Wee neeeed better pics!! If you have no were to upload go to imageshack.us.
Welcome to
1998 CamaroZ28
Old 12-15-2008, 01:00 PM
MAK567's Avatar
I Used Photobucket To Upload Do Not No How To Make The Image Bigger.
Old 12-18-2008, 01:16 PM
mosconiac's Avatar
mosconiac mosconiac is offline
You've "attached" the thumbnail from photobucket to lateral-g.net. Go back and insert the actual link from photobucket (or attach the full resolution photo to lateral-g.net)
Old 01-01-2009, 02:40 AM
Where you get the brakes from?
Old 01-01-2009, 04:43 PM
You'll end up having to type this to make it work [img]link from photobucket goes here[/img] look under the picture on photobucket's site and it'll have direct link and you can choose that/ Just click it once and it'll copy it. Then use ctrl v in between the img brackets and it should work.
Old 01-02-2009, 05:32 AM
deuce_454's Avatar
i can tell you first hand that that g-bodys can be made to outhandle most gars out there...
Jake: Hit it.
Old 01-05-2009, 02:03 PM
MAK567's Avatar
Try this a little bit bigger but picture not as good either i am trying to get someone to photoshop different wheels,but no luck yet.The brakes i will be using are cadillac xlr-v brakes they are the same as corvette without the corvette logo.they come in black with a v and flag ingraved on them
Old 01-07-2009, 02:56 AM
What rear end you got in it ?
