So I need your guy's advice on how to get a broken fender bolt out. I tried welding a nut on the end...no luck. Kept breaking off. The weld didn't want to stick all that great. I've drilled the center out and used two different type of easy outs...no luck. I've soaked it with liquid wrench...you guessed it...no luck. Today I used an oxy torch and heated the area up around the bolt and tried the easy out's again...no luck. Any one have any suggestions. Here's a pic:
