Old 02-17-2009, 01:51 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default I bought a New Engine for one of my projects! I think this is really a decent deal!
To All:
I know this company is not a sponcer on this site, however, I found them to be very helpful on one of my projects, and I thought I would pass along my experiance in an effort to help the fellow enthusiest on this site. I know there are a number of very competent sponcers on this site, many of which I have done business with, and many others I've been in contact with that I am planning to work with in the future.
I sincerely hope, and it is certainly not ment to be offensive, to any of the quality sponcers on this site. Please keep this in mind as you read this.
I had the opportunity to Visit Mast Motorsports this last weekend (They are not very far from where I live) and meet with the guys that design and build these engines. I was very impressed with the facilities and their knowledge in putting the right parts together and getting them tuned to make big power at a real fair price.
Check out their website (Below) and see what kind of engines they offer. I was able to get a very complete LS3 (427 ci.) that makes 600+ hp for $13,000, and this includes just about everything you need to get it running. They Dyno each Engine and give you the Dyno sheet, and they used really high quality parts.
I just bought a Engine for one of my projects and I am fired up. Here are the specs:
http://www.mastmotorsports.com/gascrate.php
LS3, 7.0L (Hot Rod/Muscle Car) 600+ HP/ LIST $12995
With M-90 ECM & Wiring Harness
Displacement 427 Cubic Inches
Compression Ratio 11:1
Bore X Stroke: 4.070 X 4.100
LS3 Aluminum Block
Plateau Honed to 4.070True Surface Deck
Engine Block Debured
Blue Printed Shortblock
Rev. Limit 7000 RPM
Crank: Callies 4.100 Stroked Crankshaft
Rods: Callies Compstar Connecting Rods
Pistons: Custom Mahle Motorsports Pistons
Cam: Mast LS7 Core Custom Hydraulic Cam (SS Cam, Duration @ .050 I/E 236/250, Lift I/E .648"/.648", Lobe Separation 114)
LS3 Hydraulic Roller Lifters
Manley 1 Piece Chrome Molly Pushrods
Heads: LS3/L92 Heads
Intake: GMPP L76/L92 Intake
Valve Springs: PAC 1518 Nitrided Beehive
GM Car Harmonic Damper
ACL Rod and Crank Bearings
ARP Head Bolts
ARP Main Studs
Cometic Head Gaskets
M-90 Calibrated ECM
Main Wiring Harness
Dash Harness
Air Mass Harness
Transmission Harness
EGO Harness
Bosch EGO Sensor
Fuel Pump Harness
Fan Harness
LS3 Intake
GM 90mm DBW Throttle Body
Bosch Deadheaded Fuel Rail
Bosch LS3 Fuel Injectors
Mast 8 Layer Air Filter with IAT Bung
Intake Air Temperature Sensor 560-2218 info
Crankshaft Position Sensor
Camshaft Position Sensor
Oil Pressure Sensor
Oil Temperature Sensor
Engine Coolant Temperature Sensor
Engine Knock Sensors
Manifold Air Pressure Sensor
Ignition Coils
Spark Plugs
Plug Wires
GM Foot Pedal
GM Starter
Car Water Pump
LS3 Oil Pan
GM Oil Filter
Extras: $2400 Total
1st Gen Conversion Kit
Motor Mounts for a F-Body Camaro
Fully Programmable Software Package
F-Body Front Runner Package
Hedders (1 7/8 with 3 Inch Collectors)
AN Fuel System with Inline Pump
These engine packages come with just about everything you need to really get going.
Shaun and Horace were very helpful and knowledgable about their products. This may or may not be the right fit for your project, but for the one I had in mind these guys were very helpful.
If youhave time and are interested, check out their web site and see what you think.
Good luck.
Ty
Once again, this is for general information purposes only. I had a very good experiance and just wanted to let some of the people here know about it. Please don't let anything I said here keep you from investigating and patronizing the sponcers on this site. My experiances with the fine vendors on this site have ALWAYS been positive and I was very please with the fit for the application andthe quality of the items I purchased.
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 02-17-2009, 03:26 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
WOW!!!
Good deal. Sounds like a nice power plant.
What project is this bad boy going into?
Old 02-17-2009, 03:55 PM
JamesJ JamesJ is offline
I hope everyone post up all their good deallings with every one even if they are not sponsor.
James J.
Old 02-18-2009, 01:15 PM
+1. I'm not ok at all with a website censuring nonsponsor info/dealings/experiences/etc. I'm glad you've had a good experience with them. They sponsor a number of other boards such as LS1tech and Pro-touring.com so they are easily found.
Old 02-18-2009, 02:03 PM
Weldon0405's Avatar
Weldon0405 Weldon0405 is offline
The feedback is much appreciated by those of us who haven't yet reached this portion of our projects. Do you have a build thread we could follow the transplant on?
WELDON MALBROUGH
SSG, USA
Fort Bragg, NC
It is great to be back in the States!
Old 02-19-2009, 12:28 AM
tyoneal's Avatar
Originally Posted by tones2SS View Post
WOW!!!
I know this sounds stupid to a point, but I've got a somewhat secret project I'm working on hopefully I'll have it in a showable condition real soon. I'd like for it to look good on this board.
I do like the engine. I heard one running and even with the most radical cam they offer, it would still idle at 700 rpm with not a problem.
Good Stuff.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 02-19-2009, 12:31 AM
tyoneal's Avatar
I appreciate and agree with your thoughts. At the very least it would help people find out about bad experiances they have had, and in turn it would help someone on this board avoid the same problems.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 02-19-2009, 12:45 AM
tyoneal's Avatar
Trey:
Thanks! I did want to acknowledge to the sponsors that I know that:
1) Many if not all of the sponsors on this site are at least from my experiance excellent to do business with.
2) The Sponsors pay to be here and have their products and Name known and available for us to have easy access to their website.
3) Most of all the products I have bought, have been from people on this site, and I tried to make that clear at the begining and end of my post.
I hope that discussions about the aftermarket are kept open, and also that respect is given to the people who help make this site what it is.
I am currently visiting with several vendors on this sight regarding products for the Camaro I have.
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 02-19-2009, 01:03 AM
tyoneal's Avatar
The Build thread is a good idea. I haven't ever done one, however I'll see what I can put together in the near future.
I've got some seasonal responsibilities I'm currently busy with, (I'm getting my fruit and nut orchard upgraded/exspanded/part of it replaced.) It should be finished before to long, but it's time to get the work for it taken care of.
I'll give this a go in the near future.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 02-19-2009, 04:08 AM
tones2SS's Avatar
Thumbs up
Good Stuff.
Ty
That's cool. I guess we'll just have to wait. The engine sounds like a beast from the specs.
Good luck!!!
