Old 10-04-2005, 11:09 AM
Steve1968LS2's Avatar
Default Tricks or Ideas on how to remove glue from interior floor?
I am stipping out the interior of Penny becasue I am anal like that and want to do it the right way.. the interior will end up looking almost exactly the same but I like to make sure everything is sealed up right and the right sound deadner is used..
Previous owner used some sort of spray adhesive (3M) to glue the foil backed jute to the floor of Penny. I want to clean it all off so I can coat it in POR-15 and then dynamat the whole deal.
Anything good for dissolving the glue? I was thinking some sort of paint stripper and a scraper..
Ideas and "tricks" would be appreciated!
On a side note the floors look great considering they are almost 40 years old.. Also funny that I found pennies glued to the floor to cover up some screw holes. guess I named the car right!
Thanks!
Old 10-04-2005, 11:47 AM
TravisB TravisB is offline
We use some stuff called Speedy 500 here at the body shop to remove molding adhesive on doors and stuff! not sure if will work for your app but it is worth a shot!
Kenny Davis Hot Rods
Old 10-04-2005, 01:28 PM
907rs's Avatar
907rs 907rs is offline
I've had good luck with a heat gun, putty knife and lacquer thinner..... Just not all at the same time!
Bill
Old 10-04-2005, 02:21 PM
Hmm.. I wonder if my local auto paint supply shop would carry that..
907rs: Gotcha.. no matches near the thinner.. lol
Thanks for the tips.. all suggestions are welcome!
Old 10-04-2005, 02:40 PM
All paint stores around here carry it.........! Good luck
Old 10-04-2005, 03:41 PM
Fluid Power's Avatar
Default love removal machine
This thing works great....won't damage the floors either
http://buy1.snapon.com/catalog/tools...e=snapon-store
it is a bit spendy, maybe you could write a review of it for the mag...
Darren
Old 10-04-2005, 06:55 PM
B Schein's Avatar
B Schein B Schein is offline
I’ve used those tools before, scary to run make sure your shirt is tucked in and you have on safety glass. Those wires really hurt when they come off the wheel.
Brian
Old 10-05-2005, 12:27 AM
squid squid is offline
After some elbow grease annd a putty knife, I used a wire cup brush on a 4" Angle grinder. It bared the metal but didn't cut into it. It looked like like brand new when I was done. It was a shame to cover it up. I used hammerite to spray it and then dynomat extreme.
Old 10-11-2005, 09:30 AM
By the way..
I tried the GOOF OFF stuff in a spray can.. just dusted and area with it and it all came up VERY easily with a putty knife.. I was amazed at how well it worked!
I just need to wipe it down with laquer thinner and then go to town with the POR-15.
All original floors with just a tiny bit of surface rust. Looks like she once had welded in race seats.
Old 10-11-2005, 09:55 AM
Damn True's Avatar
Damn True Damn True is offline
This is the best tool name ever!
http://buy1.snapon.com/catalog/item....re&dir=catalog
Tool, Air, Crud Removal
LOL!
