Old 06-16-2009, 10:29 AM
g356gear's Avatar
g356gear g356gear is offline
Default welding on axle tubes.....preventing damage
hey guys,
I am installing a 4 link in my 69 camaro and need to weld 4 tabs on the axle tubes. Each tab requires a 3" weld. Differential is still assembled in the car since the tabs need to be welded on with the suspension at ride height. What would be the best way to weld these on while keeping heat damage to a minimum?
