Old 04-01-2009, 09:10 AM
berlinetta091 berlinetta091 is offline
Default first car = '84 Camaro Berlinetta
I'm new here so I need some help. I have a 1984 Camaro Berlinetta that is in the process of getting a used 350 put in from a local shop. I want to keep a sleeper appearance, while slowly upgrading the suspension and drivetrain. It had a 305, and still has the stock automatic. I also want to find the original radio setup because it was missing when I got it. Everything is stock as far as I know it. I'm 17 and on a very tight budget.
Old 04-01-2009, 05:50 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Sounds like a cool project. third gens are very good cars and underestimated IMO. I have a 90 Iroc-z and its an awsome car. Not too shabby handling in factory form either. Keep us updated on the progress!
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 04-01-2009, 07:14 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
thirdgen.org is good to find parts and get info
Scott from NJ
Old 04-01-2009, 08:01 PM
The 3rd gen camaro uses the normal gm big din size with every gm from the 80s to mid 90s used easy to find in a junkyard but who knows if it works tho.Look around on http://www.hawksthirdgenparts.com/
Old 05-08-2009, 07:34 AM
Angry
As of yesterday, the 305 that the shop put in had the same problem as the original motor, there was a rod knocking. So, the project will be delayed until the shop can find another engine. But, I am still open to suggestions or help in making my first car into a decent weekend worrior and great daily driver.
Old 05-08-2009, 08:57 AM
Rhino Rhino is offline
Originally Posted by andrewmp6 View Post
The 3rd gen camaro uses the normal gm big din size with every gm from the 80s to mid 90s used easy to find in a junkyard.
The Berlinetta had a full electronic, non-standard radio. In fact, the controls didn't even mount inside the dash.
It's a rather rare item.
http://members.cox.net/berlinetta/media/84Page8-9.jpg
Old 05-08-2009, 09:07 AM
SS1156's Avatar
SS1156 SS1156 is offline
Ahhhh, yes the radio on a stick! Not one of GM's better ideas. Good luck finding one of those. Most people chucked them out the window. You are kinda limited on what you can do with that radio. Most of all....Welcome to the sickness
SOLD 1993 Saleen Mustang #20 of 56, Black & Gold sittin on 17" Sterns.
FQuick: www.fquick.com/ss1156
*New car 1970 Camaro SS clone*
* Soon to be under construction*
Old 05-11-2009, 06:06 AM
I have even looked on Ebay, but still can't find the radio setup. As far as I know everything exept the actual radio is there, but if anyone can find one in good condition, I would appreciate it. Thanks for all the help so far.
Old 05-14-2009, 08:50 PM
CamaroPat's Avatar
CamaroPat CamaroPat is offline
If you want any kind of decent sound, replace the console with a different one (without the stick and accompanying holes) and put in a regular head unit. The factory Berlinetta units (with ERS extended range sound) didn't sound terrible but you can get much better sound quality at a lower price by going aftermarket. I only suggest this because it doesn't seem like you're going for a perfectly original restoration. I've owned a handful of third gens myself and I loved them. If you have t-tops, get subframe connectors as soon as you can! Third gens handle pretty well stock, but they're structurally weak. Those cars are relatively light, too, so you won't need a ton of power to make it fun. Try to find a 350 if you can, 305's aren't great motors for revving high and their small displacement limits their torque. I hope you have as much fun with your third gen Camaro as I did with mine.
Great success rarely comes without the risk of great failure. '81 Camaro, 350, Edelbrock 750, headers, 4 speed, '97 Buick Park Ave Ultra, Supercharged 3.8L V6
Old 05-19-2009, 05:54 PM
CamaroPat's Avatar
You mentioned wanting to keep a slleper appearance. If you want to switch things up a bit, I have a 1988 Camaro with complete ground effects that I'm probably never going to use again. The car is a bondo bucket and it's a more of a greenhouse than a car now (it's been in a field for about 5 years). I'd be willing to sell the nose, rear bumper and ground effects for $150, I don't know how much the shipping would be though. The ground effects are the same as those on IROCs, so it wouldn't look extremely modified.
