Old 12-22-2005, 10:58 AM
rwhite692's Avatar
Default Disassembly for hi-temp coating?
Hi Jason,
I'm about to get my manifolds and housings high temp coated.
I would like to know if there are any special considerations or instructions for disassembly of the turbos. It looks very straightforward, but figured I should ask first. If OK to disassemble, what are the torque specs for re-assembly?
If there is a lot of associated complexity/risk, or will put me SOL if there is a problem with the units later down the road, then I won't bother, and will just do my manifolds.
Also...shouldn't the bolts on the turbo housings be set up for safety wire?
Thanks,
Rob
Project update thread here:
My Lateral-G Page
My Shop Build:
