Old 09-17-2009, 12:13 PM
donaz donaz is offline
Default Can you fit a 295/35/18 on a lowered 71 Camaro?
New here to the Pro-Touring world and absolutely dig the look. I hope you guys will chime in and give me some definitive answers. I am looking for the widest rubber I can fit INSIDE the rear wheel wells of my 71 Z without any pounding, cutting or rolling of the lips.
the car is lowered 2" with an otherwise stock leaf spring set up so the tire is definetely going to sit up in the wheel well. I was informed by more than 1 source that 275/40's on a 9' rim is the safe way to go. I have that tire on an 8" rim on an El Camino and am looking for something more aggressive for the Camaro. I had a 295/35/18 KDW unmounted that I stuffed up in there and it seemed like it would fit. But without having it mounted on a rim I couldn't be sure. Will this tire work on a 9,9.5, or even a 10" rim if it had the right backspacing? Remember I don't want to cut the lip. So, If any of you have this combo, what would be the correct backspacing? Also the front tire comes into play if I can fit the 295/35 in the back. What would be the correct tire to run in the front on an 8'rim? It needs to have the correct sidewall height to compliment the rear tire. Again, wider is better.
I hope I get some good feedback on this. Thanks Don
Old 09-17-2009, 12:23 PM
67rstbkt 67rstbkt is offline
Maybe this will help:
https://lateral-g.net/forums/show...st+tire+camaro
Rusty Bird Build Thread:
https://lateral-g.net/forums/showthread.php4?t=18566
Old 09-17-2009, 01:35 PM
some info in that thread, but not enough to make a decision
Old 09-17-2009, 02:28 PM
That's all I could find, maybe someone with a 70-73 will chime in.
Old 09-17-2009, 03:18 PM
A 295 usually should have at least a 10" rim but you can check with the manufacturer on that. I have a 295 on a 10.5 rim on a 72 camaro but the front end has been widened (fender flares). The tire is almost 12" wide and I doubt on a stock wheelwell you would do it without reducing your turning. I can take any measurements you want but nothing much is stock any more except the frame for about 3' in that section. Inside to inside tire is about 50" outside to outside is 73 1/2". My tires would be slightly shorter because they are a 295/30 and a different brand, but still close. Hope that helps a bit.
Old 09-17-2009, 04:27 PM
nice racecar but I need to see someone with 295's on a 10" wheel on the rear inside the factory wheel well.
Old 09-17-2009, 05:00 PM
That car will be street legal. Sorry I read to fast... thought you were talking fronts. It used to have 295's on the back with 10" wheels years ago with stock inner wheel wells but it had the flares. Try giving Frank at Prodigy Customs a call, I bet he can help you out with that. He knows a lot of the offsets etc. off the top of his head.
Old 09-17-2009, 08:01 PM
ok I'll give him a shout thanks
Old 09-17-2009, 10:56 PM
70rs's Avatar
70rs 70rs is offline
Another person to ask would be Jason Rushforth. He is a member her. Look up Rushforth Wheels in the vendor column on the left side of the screen or you can look him up in the members list as JayR.
I have a '70 but do not have anything mounted up yet. Good luck!
Let's see some pictures of yours!!
Old 09-18-2009, 08:35 AM
syborg tt's Avatar
Okay I like you have been doing tons of research on this
If your trying to tuck the tire in the wheel well - this is what I can tell you.
So far I've found out that a 285 -- 26 1/2" tall will fit ( 10" rim )
The 295 will fit but you have to beat the seat belt hump and may want to consider rolling the fender lip ( ps i have a fender roller - both versions now )
But the height of tire has 26 1/2 max
If your goal is to go really low then you have the worry about the fact that the rear quarters are swept or layed over big time on a second gen.
I am trying to figure out I am going to put a 28" tall tire and set that car at a 6" ride height.
One of my options would be what Dan Holohan did on the Sick Fish when he worked at Rad Rides. He actually leaned the rear quarter out and re-did the metal work.
marty-mj
