Old 11-18-2009, 03:56 AM
LowchevyII's Avatar
LowchevyII LowchevyII is offline
Default LS swap questions
So im looking to do an LS swap in my 70 nova and have a few questions for the many knowledgeable gurus around here.
-thinking of going with an LQ4 (to keep costs down) with L92 heads. What intake and throttle body should i use?
-What cam should i go with to make between 500-550 horse at the crank?
-Hope to be running a t-56 tranny.
-what fuel rails and injectors?
-finally what all do i need in terms of wiring harness and ecu for this all to work?
- also, anything else i may be forgetting
Any advice and/or suggestions would be amazing.
thanks in advance guys,
Jeff
Jeff Weidner
1970 nova in pieces
Old 11-18-2009, 07:18 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
My advice and suggestion would be to search here and at LS1tech.com and Pro-Touring.com. There's a ton of information available.
Old 11-18-2009, 01:16 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Jeff
**Depends on if you are going with drive by wire or cable. I vote for dbw. If so...you can get the truck motor, than a LS1/6 Corvette intake and you can still use the dbw TB that may have come on the truck donor.
**I would contact Comp Cam - discuss your gear ratio - transmission, and expectations.
**This would make it wise to buy a LS donor that comes with the transmission because piecing it all together is a real pain and can get more expensive than just having bought a LS1/2 with T56 from day one.
**Stock rails are fine - but that kind of hp will you will want some 35# or so injectors. SLP can also set you up with a cam and injectors together.
**I suggest you get a painless harness - and run on a 0411 PCM (especially if you go dbw)
Oh...if you go DBW, you will need the pedal and TAC module out of the donor - unless it is a 2006 - up LS with a 52 tooth wheel and the newer computer.
Confused yet? LS1tech has great info about this swap as well.
Old 11-18-2009, 05:59 PM
LowchevyII's Avatar
Default commenets and suggestions for my engine combo?
ok so heres what i am thinking. Carcraft did a build up on this thing basically.
http://www.carcraft.com/techarticles...ads/index.html
my only thing is that i want to go fuel injected, i dont think i want to go the carb route that they went so im thinking going with the
-F.A.S.T LSXr 102mm intake
-the 102mm tb with throttle positioning sensor (does this mean its drive by wire with that?)
-fast fuel rails
-35-37# injectors
-l92 heads
this is the cam they used in the artice
XFI™, XR281HR13
Street/Strip, High RPM, Works well with FAST™ Intake
so what would be suitable valve springs for this cam?
is this a decent combo or what would you guys change/suggest otherwise
thanks again guys
Jeff Weidner
1970 nova in pieces
Old 11-18-2009, 09:09 PM
70rs's Avatar
70rs 70rs is offline
Regardless of what cam you select, get with that cams manufacturer to find out what valve springs you should run with it.
And regarding the post above and the LS1/LS6 intake with the L92 heads (good intakes) I think the L92 heads have a different intake port design than the LS1/6 does. It is more like the LS7 ports (rectangle?)if I remember correctly. But please don't take my word for it, just double check.
Old 11-18-2009, 09:21 PM
ivmotor ivmotor is offline
Definitely different port configs between ls1,6,2 (cathedral) and ls3, l76, l92 (rectangle) and ls7 (huge rectangle with higher bolt pattern). The l76 and ls3 intakes will make all the power you'll need, I think they can be bought for $350-400.
Howe makes better harnesses than painless. I do a bunch of conversions and have had numerous painless failures due to pin fit in the connectors.
The oem computers are fantastic, very tunable and reliable.
Old 11-19-2009, 12:36 AM
LowchevyII's Avatar
good info guys, keep it coming. Thanks for the heads up on teh intakes. As nice as that FAST unit is, i just dont think i can swing 1000 for the intake, 550 for the TB and 200 for the fuel rails. Glad i can probably get a LS3 intake for about 500 tops that will work sufficiently
Jeff Weidner
1970 nova in pieces
Old 11-21-2009, 06:02 PM
69MyWay's Avatar
I'd like hear more details about the pin issue - and how recent/old has this problem been. They now have a high dollar machine that every EFI harness goes in for a full go/no-go electrical test unlike anything else out there. Perhaps as a result of failures...or just trying to prevent them.
I have run Howe products with success as well as currentperformance and others. Been fortunate to have good luck with all of them...but remembering at the same time...there's no such thing as bolt on...when hot rodding! LOL!
Old 11-24-2009, 06:28 PM
I do mostly sand rails and rock crawlers so they might be more severe use...
painless #60217 round trans plug 2-3 solenoid wire no continuity. Found insulation not sufficiently removed from wire before crimped. 3 years ago
painless #60520 bank 1 coil pack intermittent main power. Found loose crimp. 2.5 years ago
painless #60217 bank 2 coil pack intermittent #6 spark. Found plastic flashing keeping pin from locking into connector. 2 years ago.
None of these were faulty out of the box, they took time to show problems. The later two were a bitch to find and were worsened by vibration and heat, but the poor crimp quality is what caused the failure.
I haven't had an issue with Howe, but I've only used them for 2 years. The painless in my car hasn't had problems either.
Old 11-24-2009, 07:31 PM
Z06vette's Avatar
Z06vette Z06vette is offline
If you get the factory engine harness with your donor, you can have it sent out to be reworked. I had speartech do mine, nice quality work from what I can see on mine. A local guy did a 5.3 motor in that body style nova with a cowl hood, and all the truck accessories/intake fit under the hood- barely. I am not sure what motor mount setup was used or if he made them himself to gain some clearance. A 6.0 would be the same fit A nice cam, long tube headers, and a good tune should get you close to 500 crank HP. Keep us updated on your project!
