Old 03-17-2010, 02:10 PM
Default Hey 69 Camaro guys! Did you see these yet?
We had a press release in CHP about our new Phantom side marker lenses, but I totally forgot to put anything up on the boards.
These are injection molded polycarbonite lenses that replace the chrome bezel on the front and rear of the 69 Camaro. (We offer a sheetmetal cutting template for those who would want to add these to anything else)
Here is our show display with multiple painted lenses with the llight both on and off. This is the way they come from us; black smoked lens.
lights off:
lights on:
Close up of the back side of the lens:
These are super easy to install as well. You just remove the barrel nuts from the factory bulb housing, and remove the chrome surround from the car, and re-install our Phantom lens in its place.
More to come....
Tyler
Old 03-17-2010, 02:28 PM
The best part?
You can paint these to match the color of the car so they blend in. On a black car simply install them. On other color cars you can do all sorts of neat tricks: (keep in mind these are taken in braod daylight, night will make them much brighter.)
Here is blue with the lights off:
Blue with lights on:
Red with lights off:
Red with lights on:
Silver with masked off window, lights off:
Silver with masked off window, lights on:
All silver with lights off:
All silver, lights on:
These will require a slight modification to install on the front as the shape of the sheetmetal is slightly smaller than the back. A quick grind with a dremel to our lens will make it pop right in.
These will also fit 69 Chevelle. They are $95.00 for a set of 4 and are in stock at the moment.
Any questions?
Tyler
Old 03-17-2010, 02:38 PM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Ilike this part, should work for all cars.
Old 03-17-2010, 02:59 PM
We are considering having a sheetmetal weld in patch panel that already has the hole cut out of it.
Tyler
Old 03-18-2010, 01:56 PM
Denvervet's Avatar
Denvervet Denvervet is offline
Will this work for a 68? I am not aware of the relative sizes between the two.....I like the stealth look.
68 camaro, 572, tko
Old 03-20-2010, 12:35 AM
70rs's Avatar
70rs 70rs is offline
I like those Tyler. I did see the write up on them in the mag. Glad you posted here too.
Eric
Old 03-21-2010, 09:10 PM
nvmyss nvmyss is offline
Default 69 Chevelle
Here is the Chevelle with Anvil marker lights.
I really like how clean these look.
Adam
69 Chevelle SS 396 < --Sold
67 Camaro
06 2500 Dodge Ram Diesel
93 Beretta GTZ
04 S60R ..Gone
Old 03-22-2010, 09:18 PM
Blake Foster's Avatar
great idea!
how about some flush mount ones?
Blake Foster
www.speedtechperformance.com
Old 06-17-2010, 04:02 PM
We have a new way to install a set of our Phantom lenses onto any car- We now offer a stamped steel plate weld-in patch panel:
You can get a set of 4 weld-in patch panels and Phantom lenses for $190. The panels are $95 per 4 as are the lenses. You will still need either the 68 or 69 Camaro backing lens to complete the install (the amber and red colored bulb holders.)
Tyler
