Old 08-25-2008, 06:49 PM
youthpastor's Avatar
Default 1st Gen LS1 computer location
so where did you guys put the pcm?? I have vintage air and want to hide all my wires- any pics?? thanks-Chris
Old 08-26-2008, 01:59 AM
deuce_454's Avatar
depends on the harness.. an oem harness isnt long enough to mount the ECU in the passenger compartment.... an aftermarket one is...
Jake: Hit it.
Old 08-26-2008, 06:13 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Chris, I think I'm putting mine on the inside od the passenger fender. towards the front , mounted on the inner fender. it will get plenty of air and you won't be able to see it. The other option is through the tunnel and hidden in the front part of the console.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 08-26-2008, 05:03 PM
LS1NOVA LS1NOVA is offline
Mine is inside the car under the dash near the center. Stock harness with a
grommet near the top of the bellhousing. No pics sorry.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 08-26-2008, 05:12 PM
sweet that should hide everything nicely- I just need to see if I have enough room with the vintage air- guess i better mock it up
Old 08-28-2008, 05:08 AM
bigtyme1's Avatar
Originally Posted by Jamess113 View Post
Not the best picture but here's where I mounted mine.
Jay, That looks Good. Where did you bring in the harness and what vintage air unit did you use? Any more picks?
Also how did you mount it?
69 RS Ragtop
[email protected]
Old 08-30-2008, 12:18 PM
thanks guys- heading out to the garage now to mount the Vintage Air and mock up the comp location- looks good thanks for the idea
Old 09-03-2008, 12:37 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
I put mine on the firewall above the passenger feets. It is sandwiched between the VA unit and the firewall and the stock harness has been used.
I made my own bracket for the VA unit. It was made so that it was enough room for the ECM. My bracket also moved the VA unit more to the left so that the floor vents are more centered over the transtunnel. It required some cutting in the dashboard bracing.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 09-03-2008, 06:35 AM
Mike Norris Mike Norris is offline
Supporting Vendor
Under the dash is usually the best, but try to also make it as excessible as possible also. In the event a wiring or PCM issue crops up, the last thing you want to do is disassemble the car to test a narness or replace a PCM. I have tuned quite a few hybrid LS cars as well as FAST and DFI and whent the units are really tucked away it can become a nightmare.
Hope this helps.
Mike Norris
Mike Norris Motorsports
Raymonds Performance
3828 Clarks Creek Road
Plainfield, IN 46168
407-616-2518
www.mikenorrismotorsports.com
[email protected]
Visit Our Facebook Page
Old 09-03-2008, 02:50 PM
thanks Mike- good point- hate standing on my head underneath a dash
