Old 08-14-2010, 05:41 PM
protour73 protour73 is offline
Post Hydroboost Installation w/ pics.....
I started with the Hydratech Hydroboost kit which came complete with everything needed for the basic installation. After reading many many threads about this install, I discovered a modification which runs the low pressure return line direct to the Power Steering Pump. This eliminates a "T" fitting in the basic kit and prevents any fluid feedback to the HB unit.
Parts for that mod were ****** Hydraulics part# 8203 (5/16-24 O-ring male to -6AN male), 2-Russell 613161 90* -6AN hose ends, Russell 670850 -6AN Fuel Cell Bulkhead fitting, ****** Hydraulics part# 1451 2pack of 3 Hole Hose Clamp Separators and Russell Stainless Steel braided low pressure hose.
First drain the PS pump reservoir, remove old PS hoses from pump and steering box
Then remove old master cylinder brake pedal rod from the brake pedal
Disconnect the front and rear brake lines and remove the old master cylinder
I made a new gasket to fit between the new HB unit and the firewall, I used Felpro# 3157 rubber fiber gasket material from NAPA Auto Parts.
Then I installed the HB unit. Before installing the Wilwood master cylinder, install the two high pressure lines and the low pressure return line. Installation of these hoses is nearly impossible if you install the master cylinder first (ask me how I know). Remove the preinstalled brass 90* fitting for the low pressure return port from the HB unit, and replace with the THI 5/16"-24 O-ring male to -6AN male fitting on the HB unit. Be sure to torque ONLY to 10 ft. lbs. as the threads for this fitting can strip very easily. Use one wrench to hold this fitting while tightening the Russell part# 613161 90* hose end with another wrench.
Day 2) I drilled a hole above the fluid line in the PS pump reservoir and installed the Russell #670850 -6AN Fuel Cell bulkhead fitting in the reservoir for the low pressure return line from the HB unit. I stuffed a clean shop rag into the reservoir, spread some grease on the end of the drill bit(metal particles stick to it), and vacuumed real well with the shop vac to make sure no metal particles got into the reservoir.
Then I cut to proper length, the two high pressure lines coming from the HB unit and installed the Aeroquip fittings and then installed them in their proper locations, and also installed the Russell part# 613161 90* hose end on the other end of the low pressure return line and installed that on the PS reservoir.
Next I need to fill the power steering pump with fluid, and bleed the system, checking for any possible leaks. I'll be securing the two hose clamp separators to the inner fender, I need some new hardware for that. I also need to bend some new lines for installation of a proportioning valve and then bleed the brakes. Then a test drive!!
Old 08-14-2010, 07:14 PM
lil427z's Avatar
lil427z lil427z is offline
you will like it.
rick k
Old 08-14-2010, 08:26 PM
Very interesting post thanks.
Old 08-14-2010, 10:04 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
Looking forward to seeing those pics! Edit: Nice looking install!
From my experience, if the lines are going to touch any part of the body they need to be clamped down. They will be very loud if they touch the inner fender. Once I worked that out, it is a great system!
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
Old 08-15-2010, 07:07 AM
staged67gspwr's Avatar
staged67gspwr staged67gspwr is offline
Looks really nice,who did you get everything from?
George
`67 Buick GS ,"The Black Widow II"494ci,Stage 2,5-speed G-Machine
Old 08-15-2010, 03:20 PM
The Hydroboost unit is from Hydratech. http://www.hydratechbraking.com/
Old 08-15-2010, 03:28 PM
I was told they dont sell to the public?only to dealers,you got it from them?
George
Old 08-15-2010, 04:30 PM
I actually purchased it from a private party on NastyZ28.com, who got it from Frank @ GPSuperstore.
Old 08-15-2010, 04:39 PM
Ok cool.
George
Old 09-11-2010, 05:40 PM
Finally finished the brake plumbing. had to make up some new lines for the different configuration with the Hydroboost setup. Added a new hard line from the "B" port on the Wilwood master, back to the new proportioning valve for the rear brakes. I decided to move the "Tee" fitting for the front brakes up to the inner fender. That required a new hard line from the "A" port to the "Tee".
I also made up a different low pressure return line from the Hydroboost back to the power steering pump reservoir. I made it longer to run it more forward away from the heat of the #1 cylinder header tube.
