Old 04-22-2011, 04:51 PM
ht turbo monaro's Avatar
ht turbo monaro ht turbo monaro is offline
Default wilwood brakes advice
Looking at putting on a set of wilwood brakes, superlite 14inch 6 piston front and 4 piston rear,also iam running wilwood pedal box , After some guys that have put the same on there car, and there take on how they work and if there happy with them.
Old 04-23-2011, 09:19 AM
wheelsup351 wheelsup351 is offline
I put Wilwood brakes on my car. They work great and were a snap to install.
Two points of caution: 1) they kicked my wheels out an inch on either side requiring me to change offset/backspace; 2) not all wheels and centercaps will clear the wilwood hub.
I'm sure every car and app is different, but those are my experiences.
I have no regrets.
Old 04-25-2011, 03:59 AM
69x22's Avatar
69x22 69x22 is offline
Biggest complaint I have is the parking brake is very hard to apply, people are snapping cables trying to get them to hold. Don't know if you are going to run a parking brake or not.
Old 04-25-2011, 08:44 AM
Nobodies after market parking brake works. I've had Wilwoods and Baer -- and they just don't hold. Some would refer to these as "emergency brakes" -- oh... that would be a HUGE mistake! They won't even hold on a 1% grade when you're dead stopped.
Old 04-25-2011, 12:42 PM
69x22's Avatar
Especially on a Nomad when you pull it up with your hand!
Old 04-25-2011, 04:40 PM
Thanks guys yes was going to run park brake but maybe not , is there a park brake that does do the job that you know , but you guys are happy with the stopping power of the wilwoods??? thanks for your advise
Old 04-25-2011, 04:53 PM
Brakes are a SYSTEM -- and if the system is all done well and matches --- from the pedal ratio - to the master cylinder diameter/volume - etc - all of these big brake systems work killer.
One thing some buddies have had to get used to -- COLD braking.... some of these systems have street/track pads in them and the cold braking takes a little getting used to.
Another thing people fail to do -- BED THEM.... and I mean get them smoking hot bedding not just a few random hard braking stops.
Old 04-25-2011, 05:07 PM
Blake Foster's Avatar
The Bare setup in My Nova works Wicked!! i can leave it parked in my driveway that has a decent grade in neutral and no issues
Blake Foster
www.speedtechperformance.com
Old 04-25-2011, 05:12 PM
Talking
Good! Maybe I'll bring mine up and you can make it work!
Old 04-25-2011, 07:55 PM
Greg i am SURE it is more good luck than good management!!! as i do know that alot of the time they do not work all that well.
but feel free to come by any time.
Blake Foster
