Old 02-08-2012, 03:11 PM
orangevert's Avatar
orangevert orangevert is offline
Default fuel injected tank on a 69 camaro?
I was told I could buy the fuel injected tank and just run my carb set up for now?
Could I just use mechanical pump to pull gas from tank and leave electric pump unhooked until I do my Ls swap? Im not able to do LS motor at this time.
The car is mini tubed so I need to run a narrowed tank and hate buying thing twice.
Thanks Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 02-09-2012, 08:22 PM
Camaro Dave's Camaro Dave's is offline
Hello !!
In my past experience you cannot pull the fuel through the injected pump
let me know if I can help with anything else
I own a local shop Camaro-Daves.com
call me if you need anymore help or advice 303-332-6379
Old 02-10-2012, 06:48 AM
orangevert's Avatar
Originally Posted by Camaro Dave's View Post
Hello !!
Thanks Dave
Kirk
Old 02-10-2012, 07:12 AM
orangevert's Avatar
Hello !!
Thanks Dave
Kirk
Old 02-11-2012, 06:32 PM
orangevert's Avatar
Originally Posted by orangevert View Post
Thanks Dave
I went down to CamaroDaves shop on Friday, The guy is a class act and has a great shop, 6- 69 camaros in various phases of builds, He spent a 1 1/2 walking me through his shop an let me pick his brain on several items on my build....
Thanks again Dave, his 69 vert camaro is stunning... You need to put a few pictures of it..
Kirk
Kirk
Old 02-14-2012, 10:10 PM
Kirk
Thank you Kirk for the kind words , it was a pleasure meeting you and talking shop/cars!
here is a pic of my 69 vert Camaro ..... I plan to start posting pictures of the build from start to finish on here asap
Name:  69 convert. camaro.jpg
Old 02-14-2012, 11:10 PM
hud697's Avatar
hud697 hud697 is offline
What shade of blue is that? It's beautiful
Overkill is an often underrated achievement.
1969 Camaro - work in progress
2011 Camaro 2SS/RS A6
Old 02-15-2012, 07:12 AM
thank you , its 2009 corvette jetstream blue
Old 03-23-2012, 07:55 AM
marksp marksp is offline
Thanks Kirk
I wish I had done that! I bought the DSE carb tank for my '69, and now after 1 tank of gas decided to go EFI and now need a new tank!
Old 03-24-2012, 02:19 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default Check out Tanks Inc or Aeromotive
Check out tanksinc.com, they have bolt in / in tank fuel pumps that you might be able to use with your existing tank. It uses a walboro pumps and depending on the unit, some have built in sumps right under the return fitting dump. As I recall, you need to take the tank to a radiator shop and have it boiled out to remove the flammable atmosphere, then cut out a hole in the top, install a ring to bolt up the top of the pump assembly, tack it in with a couple of welds, then install the pump into the tank. Ask around and see who has used one. I thought Aeromotive had something similar too.
http://www.tanksinc.com/index.cfm/pa..._id=6/art6.htm
DETONATOR - 69 Camaro RS
