Old 06-14-2011, 11:40 AM
brandonc707 brandonc707 is offline
Question 1st gen camaro steering box?
I have a 67 camaro that I am ready to upgrade the steering system on. It now has a factory power box with no pump hooked up
I searched these forums and haven't really found any answers...... What box and pump would you guys run on this car? I want to also upgrade the column to an ididit unit at the same time. This car will not see any track time, but I would like to be able to have some fun on the twisty roads up the california coast
Thanks in advance for your help,
Brandon
Old 06-14-2011, 11:42 AM
jy211's Avatar
jy211 jy211 is offline
Lee quick ratio box I use the pump that came in my tru trac system with it.
Old 06-14-2011, 01:00 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Brandon
Take a look here for the 3rd Gen IROC box alternative: http://www.camaros.net/forums/showthread.php?t=103139
Also, if you "upgrade" to an Ididit column (not really a performance modification if your factory column is in good shape), make sure it's collapsible - the factory colum is.
