Old 05-14-2011, 09:38 AM
jocko124 jocko124 is offline
Default Recommendations for Hydraulic Clutch kit
Gents,
I'm about to pull the trigger on a T-56 Magnum. I'm planning on getting a McLeod RST Clutch and was wondering which Hydraulic kit (TO Bearing, master cylinder, remote reservoir) I should get. I guess what I'm really asking is what's the best throwout bearing to get?
Lee
1966 Cutlass
The difference between truth & fiction: fiction has to make sense.
Build Thread:
https://lateral-g.net/forums/showthread.php4?t=31963
Old 05-14-2011, 05:51 PM
The WidowMaker's Avatar
subscribing since my decision is only a couple months away.
not to hijack a new thread, but why the RST? the guys at mcleod actually convinced me to return my rst and go with an rxt. im only at 600 hp, but they said that it would be much more friendly. the different compound allowed for some abuse and damage, but with no permanent damage since it would "fix" itself. the rst would have to be rebuilt.
"The WidowMaker"
Old 05-14-2011, 09:24 PM
The Hurst Driveline Tech guy was telling me the RST was the way to go and has great street manners--although we did not discuss the RXT---for what application did they recommend the RXT vs the RST? Not to mention I'm at 550 HP and probably would never exceed 700 HP. Having said that I have not talked to the McLeod guys. I have heard that the McLeod TO bearings are not very good--but this is not my strong suit and I'm looking to get a quick education via this thread!
Lee
1966 Cutlass
Build Thread:
Old 05-14-2011, 09:56 PM
Ron in SoCal's Avatar
Hey Lee - I'm somewhat in the same boat as you and Tim above. 600 hp, RST for street manners and I bought the McLoed TO bearing for my T56 magnum. I've heard bad reports about it too, and it was very expensive (!), but the thing looks like a piece of aircraft engineering. I'll snap a pic this weekend and post it up.
Ron in SoCal
69 Camaro in progress
Old 05-15-2011, 09:12 AM
they said any application where you could smoke the clutch (auto x, road racing, drag racing etc.). from what i have read, the rxt is VERY street friendly.
ive heard that as well. but to their defense, i havent heard much good about any t/o bearing.
"The WidowMaker"
Old 06-17-2011, 06:17 PM
BTTBSS BTTBSS is offline
Default Clutch release systems
I just bought the TO bearing and lines from American Powertrain. Bearing looks very similar to the McLeod unit but AP says theirs has larger seals that are supposed to fix the leaks reported on the McLeod unit. I had some questions about the installation and took my TKO-600 by their shop. They put it on a bench and installed the parts. I had a different bearing retainer so they took one off a new trans and I was out the door in under an hour.
Trans goes back in the car this week-end so I can't report on how it all works yet, but they get A+ for customer service.
1996 Impala SS, Red Bow Tie Mod
Old 07-01-2011, 05:58 PM
American Powertrain American Powertrain is offline
Is this Hydraulic throwout bearing week? I also just got one from American Powertrain. Soooo much better and pedal effort is fantastic. I think the master cylinder they use was part of the solution.
http://www.americanpowertrain.com/GM...hydraulic.html
Old 07-01-2011, 08:59 PM
what/whos were you using before? i still havent made up my mind......
"The WidowMaker"
Old 07-02-2011, 09:59 AM
Looks like I'm going with the McLeod 1400-30 unit.
Lee
1966 Cutlass
Build Thread:
Old 07-02-2011, 10:01 AM
Fluid Power's Avatar
Please don't. I had 2 and ended up with a RAM unit. Tons better.
The Mcleod leaked right out of the box....Twice! I will give you the one I just took off if you enjoy that kind of punishment.
Seriously. They are junk.
I used a RAM unit that mounts using the stock bearing retainer. (TKO 600) Straight forward to install. Take a lot of measurements and then shim accordingly.
http://www.ramclutches.com/Products/...se_bearing.htm
Hope this helps. If you have any questions, ask away.
Darren
