This is a project. Title in hand. Tons of extras with this car. Clean title in hand.
1968 Camaro V8 Car. Has a 355 and auto trans in car. The engine and trans are in,but not wired and plumbed. Note: The engine and trans came with the car. I was told they were fresh rebuilds, I never got far enough to find out.
It comes with the following extras:
1.The car was blasted and primered then the work stopped. No rust! Interior is out of the car. You can see everything.
2. Shaved door handles and gas door.
3. Powder coated: Front clip, core support, upper and lower control arms and fender braces.
4. MSD box 6al, HEI distributor Autometer
Brand new parts- some on some in boxes:
1. Vintage Air Kit
2. New Wiring harness
3. Headers
4. 18in Wheels and Tires
5. Detroit Speed: Rear leafs, front springs, and subframe connectors
6. Dynomatted
7. Gas tank with rear cut for external fuel pump with AN fittings
8. New Wilwood 12 in rear brakse and 13 in 6 piston fronts. The rears are on the fronts in boxes.
9. New AGR steering box on car
10. New Stainless Sorks body mounting kids
12. New Stainless front accessory bolt kit
13. New Headlights
14. PPG Paint- primer was open but good, both paint and primer.
15. New emblems
16. New Body bushing kit
17 New Sway bar kit
18. Has modern front accessory drive: alternator and powersteering.
19. Has: Holly carb
20. Edelbrok intake
21. Mini starter
22. New brake lines.
23. Tons of original parts too. Extras as well.
