Old 09-04-2011, 06:24 PM
phillym5 phillym5 is offline
Default Lets see your battery cut off switch!
Im going to instal a battery cut off switch on my 69 Camaro... but im having a hard time deciding what switch would look best and where...
So if anyone has one mounted already.. post up a pic!!
thanks...
Old 09-04-2011, 08:07 PM
70rs's Avatar
70rs 70rs is offline
Do you want it outside of the car for track safety , or inside for security?
Outside, under the rear bumper in an obvious spot.
Interior, dont show pics of it on the internet.....no security at all if the world knows where to find it.
Where is your battery mounted now?
Eric
Old 09-04-2011, 08:37 PM
I have two batteries in the trunk.
I would like to see mounts on the outside of the car. I just cant figure out where i would want to mount it.
Here' the rear of my car...... suggestions??
The ASP badge is no longer there.
Old 09-04-2011, 10:01 PM
Van B's Avatar
Van B Van B is offline
See the gas cap? When the SS is level, the switch is on. Off is in the position shown. Crap, just gave away my stealth security device. I wouldn't necessarily do it on a 69, but you said to show them, so I did.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 09-04-2011, 10:19 PM
G-Body's Avatar
G-Body G-Body is offline
Still have to build new rod and knob for it but i mounted mine in my frenched anttenna so it appears as an antenna push off pull on!
By profleetline at 2011-05-22
Old 09-04-2011, 10:45 PM
I have a feeling he's doing it for safety and not security. Probably to go down the 1/4 with 1000 hp. I've got a little trick up my sleeve for security as well but it's not as trick as you guys. I ain't sharing on this forum. I really think a thief will tow off our cars in lieu of hot wire anyway... I've yet to have a problem running down the 1320 with no switch but I think it's a smart decision in the event of a short or fire. I'll eventually put one in my car. It will likely be through the rear fascia as I like function over hiding **** anymore.
Old 09-04-2011, 10:55 PM
70rs's Avatar
Mine will be outside, behind the flip down license plate where the gas filler would normaly be.
Eric
Old 09-04-2011, 11:09 PM
FYI, it needs to be visible to run sanctioned 1320 if tech has a hard on...
Old 09-05-2011, 05:46 AM
absinthe absinthe is offline
G-body- that is an awesome idea!
Old 09-05-2011, 05:52 AM
SS454 SS454 is offline
I don't know if you can see it that good with the picture quality, but it's in between the two filler caps.
