383 stroker
Was going to build this my my new datsun Z project but decided to go a different route with the build. Most all of the parts are new. Needs to be balanced and assembled. Located in Stockton,ca.
209-609-4133
1 pc.. fresh...350 roller block...4 bolt mains...clearanced for stroker crank...060..really 388 cubes
New...Eagle cast 3.75" stroker crank
New...Scat 4340 forged 5.7" rods
New...Summit Hyper pistons..part # SUM173383-60
New ..Summit moly rings
New...Summit double roller chain
New...Summit oil pump
New..ARP oil pump stud
New..OEM style 8" 400 balancer
New..400 flexplate
New...roller lifters.....spider/dogbones
New..Summit freeze plugs
New GM black center bolt valve covers
New..valve cover gaskets
New...1 piece oil pan gasket
New...header gaskets
Used Edelbrock Torker single plane intake manifold..great shape
Used...vortec rockers..great shape
Used...vortec style rear sump oil pan..great shape
Used...head bolts..great shape
Used...GM performance cast iron water pump..low hrs..like new
Heads...Protopline 220 angle plug cast iron heads....2.02/1.60 exhaust. Needs rocker studs/valve springs etc. Some light rust in a few runners from sitting. Valve guides and great shape and low hrs on the heads. Supposed to flow killer...300 cfm at .650 lift.
I will take $1200 for the complete set up. I do not want to part it out at this time. If I do down the road I will update the post.
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
