Old 10-22-2011, 07:04 PM
WicKeD_SS's Avatar
WicKeD_SS WicKeD_SS is offline
Default 18x8 265?
Can you fit a 265 35 18 on a 18x8 rim? I have a 245 and want to get more meat up front. I was looking at Tire Rack and they say a 265 fits a 9 to 10 inch wide. Seen a camaro with a 265 on 18x8 rim in super chevy mag but didnt know if it was a miss print and didnt want to order tires that wont work with my rims. Thanks for your time!
-Brian
WicKeD
Old 10-22-2011, 09:52 PM
rjsjea's Avatar
rjsjea rjsjea is offline
They'll work fine. I have 255's on an 18x8.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 10-22-2011, 11:33 PM
intocarss's Avatar
You're good
Old 10-23-2011, 04:57 AM
LS1-IROC's Avatar
LS1-IROC LS1-IROC is offline
What tire brand? Some tires tend to run narrow. Id probably stay at a 255 max.
Old 10-23-2011, 08:25 AM
WicKeD_SS's Avatar
I was looking at TOYO R888 or BF Goodrich KDW2. Im trying to get a wider tire with out sending my rims in to be rehooped for a 9 or 10. But I want the car to be safe and ill do what I need to do to insure that. If you guys are saying stick with a 255 maybe I should for now.
Im trying to get as close to I can to get a 275 without rehooping. Is there that big of a diff between say 255/265 then a 275? Would hate to spend the extra money to get a wider rim if its not going to be a big advantage.
Again thanks guys for your help!
WicKeD
Old 10-23-2011, 08:28 AM
BIG difference in those two tires. You can cheat and put a smaller R888 on your car and have equal or better performance in comparison to the KDW.
Old 10-23-2011, 02:33 PM
WicKeD_SS's Avatar
So what do you think Todd, should I get a 255 R888 and save some money on re hooping, or send them out so a 275 would fit. I know you said a 275 would be ideal for a BBC car. would the 275 make the turns that much better on over a 255?
WicKeD
Old 10-23-2011, 03:09 PM
You know what I would do. A bigger tire will increase grip marginally but having a front to rear reasonable stagger is just as important. I think you are brining in some other variables with your tie rod ends by going over an 8" wheel. It's your wallet, you can always upgrade later.
Old 10-23-2011, 05:28 PM
WicKeD_SS's Avatar
Sound like ill send them out then Thanks for your input!
WicKeD
Old 10-23-2011, 06:32 PM
Make sure your backspacing is dead nuts before you pay to have them rehooped.
