Old 03-23-2012, 07:11 PM
Default 04-06 GTO seats in 68 Camaro
I have a 68 Camaro with factory console. Will the factory seats front and rear fit without much modificatons from a 04-06 GTO?
Thanks, Kevin
Old 03-24-2012, 09:40 PM
1Bad68Cat 1Bad68Cat is offline
Not sure if 68 and 69 are different in terms of seat platforms, but I installed a front set into a 69 camaro. It does require a bunch of modification if you intend to keep the power function, which is what I did. This was to keep the seat bottom at the same height as factory seats.
Old 03-26-2012, 12:03 PM
J2SpeedandCustom J2SpeedandCustom is offline
Just take the factory seat riser out and make your own mount. You will save time and increase head room, those GTO seats are thick!
Jeff Allen
J2 Speed and Custom
Old 03-26-2012, 03:30 PM
Thanks guys for the info, they do look pretty thick. I will have to think about that install
Kevin
