Old 03-16-2012, 02:11 PM
Track Junky's Avatar
Default Sway Bar Rates
I'm in the process and planning to relocate my front sway bar to the top of my frame rails. In order to do that I need to know what my existing sway bar rates are so that when I go to a splined bar I know what size bar and length of arm to go with. Also going to drill 3 holes in the arms at 1" apart for adjustability.
I called Hellwig, DSE, Hotchkis, and Global West and this is what they gave me.
Hellwig 1 1/8 Tubular 600 lbs/in
Hellwig 1 1/8 Solid 720 lbs/in
DSE 1 1/8 Tubular 1532 lbs/in
Global West 1 1/8 solid 1279 lbs/in
Hotchkis 1 1/8 Tubular 750 lbs/in
Gaetano Cosentino
Old 03-17-2012, 01:10 AM
Does that make sense that Hotchkis' tubular has a higher rating than Hellwig's solid in the same diameter?
Old 03-17-2012, 02:31 AM
Motorcitydak Motorcitydak is offline
75% of the torsional (twisting) load is handled by the outer 25% of the material in a bar...but still usually a hollow bar has to be slightly larger in OD to equal a slightly smaller solid bar. Perhaps it has to do with the chemistry of the metal?
Old 03-17-2012, 11:16 AM
I was blown away at the numbers they gave me. I was expecting to see around the 450 lbs/in range.
If you go to Speedway Engineering's website the 1 1/4" x 42" solid bar is 498 lbs/in with a 10" arm.
I realize that the bars I listed only have about a 6 1/2" arm but regardless of that the rates I was quoted seems huge.
Gaetano Cosentino
Old 03-17-2012, 11:19 AM
Now it should be stated here what sway bars essentially do, even though I know you may already know this. What a sway bar does is counteract the action of body roll during cornering by transferring spring rate from the inside wheel to the outside wheel in a corner. This means that you don't actually get any added spring rate; you just subtract it from one side and add it to the other. This has the ultimate effect of transferring load from the inside tire to the outside, which has the visual effect of compressing the suspension on the inside of the turn and expanding the suspension on the outside of the turn (thus limiting body roll). This is good mainly because it smoothes the speed of weight transfer during quick transitions and also limits the camber change experienced at the corners of the car through suspension travel. And of course, using this concept one can dial in the amount of total loading on the outside tire by varying the effectiveness of the sway bar (stiffer bars equal more transfer). And the beauty of all this is that it mostly only occurs during cornering, so our straight line spring rates are not affected. The other thing Ok, so hopefully now you all understand this concept. This is the most important part though, so if anything is still fuzzy read this again until you get it. Also, here's an example of how this works:
-For this example we will use a sway bar with a roll stiffness of 250 lbs.
Left front static load: 1000lbs
Right front static load: 1000lbs
-lateral weight transfer in a right hand turn
Left front: + 500lbs
Right front: - 500lbs
Total weight transfer: 1000lbs
-load transfer of sway bar(which is 250 lbs):
Left front: +250lbs
Right front: -250lbs
-total effective cornering load for this example:
Left front: 1000 + 750= 1750lbs
Right front: 1000 - 750= 250lbs
-without sway bar
Left front: 1000 + 500= 1500lbs
Right front: 1000 - 500= 500lbs
Gaetano Cosentino
Old 03-17-2012, 11:22 AM
None of those numbers make sense to me. Look at the hollow DSE as opposed to the Global West solid.
Gaetano Cosentino
Old 03-17-2012, 11:26 AM
Could be, but those numbers I was quoted seem high. According to Speedway Engineering, they test the bars by twisting the bars 5* which he told me equated to 1" of bar lift.
Doug at Global West was the last of the manufacturers that I talked to and he told me he tested the same way.
Another thing about the bars I listed is that the manufacturers dont tell us wall thicknesses for the hollow bars.
Gaetano Cosentino
Old 03-17-2012, 01:40 PM
Sieg's Avatar
Sieg Sieg is offline
This software may be worth the money:
http://www.speed-wiz.com/
http://www.speed-wiz.com/calculation...alculation.htm
I have no first-hand experience
Old 03-17-2012, 03:55 PM
Thanks Sieg, neat software and inexpensive.
In order for me to achieve the rate of my currently installed DSE sway bar with a relocated splined bar with 10" arms I would be to go to a 37 1/2" long bar.
Something doesn't seem to jive. Dont see how the rates could have such a large spread.
Gaetano Cosentino
Old 03-17-2012, 04:32 PM
Are some manufacturers using combined and others individual values.(Both sides vs. one)?
