Old 04-03-2012, 04:31 PM
intocarss's Avatar
Default ACC fuse??
I had a quick short (ground wire quickly touched a hot wire) to a wire that was hooked to the ACC male tab on the fuse panel and now the ACC male tab on the OEM fuse panel has no power. The IGN tab still does..
Is there a hidden ACC fuse I am missing? Thanks
Old 04-04-2012, 05:03 PM
intocarss's Avatar
No one knows??
Old 04-04-2012, 05:14 PM
dhutton dhutton is offline
Fuseable link in the wiring? Either that or you might have damaged the ignition switch.
Just a couple of guesses.
Old 04-04-2012, 06:24 PM
camcojb camcojb is online now
I initially though fusible link, but I don't think he'd have battery power at the fuse box. Next in line is the ignition switch.
Old 04-04-2012, 07:29 PM
intocarss's Avatar
Will check those things Thanks
