Old 03-23-2012, 09:36 PM
Rick D's Avatar
Rick D Rick D is offline
Question Which solid body bushings??
I need to order my body bushings this week, I am going with DSE solid bushing. Which should I use stock or the 1/2 hight ones??
Rick
Old 04-01-2012, 10:24 PM
coolwelder62's Avatar
Rick,If you are using a T-56 trans use the stock ht.That will give enough trans tunnel rm. w/o getting out the BFH.Kevin used the 1/2 ht.and had move the tunnel a little bit here and there.Made it pretty tight in some spot's.
