Old 06-10-2012, 06:05 PM
ProTouring442's Avatar
Default GM A-Body IRS
Since I have been working and reworking my '72 442 convertible for something like the last 15 years, I thought I might "upgrade" to IRS. Why not, right? I figure I will sell my Currie 9" to fund this little project.
So I figure I have six basic options.
1) C-3 Covette
pro: Uses the half-shaft as the upper control arm. This makes narrowing difficult, but it also alleviates the problem of upper control arm/frame interference.
con: The unit is difficult to adapt given the transverse spring, and trailing arms.
2) '69-'87 Jaguar
pro: Uses the half-shaft as the upper control arm. This makes narrowing difficult, but it also alleviates the problem of upper control arm/frame interference. Comes in an easily adaptable "cage." Center section is essentially a Dana 44. Readily available for little money.
con: Unknown axle strength. No trailing arm.
3) MN12 Thunderbird/Mark VIII
pro: Strong. Comes on a readily adaptable carrier.
con: It's 2" too wide. Not easily narrowable (cast lower control arms).
4) Mustang Cobra
pro: It's an inch or so narrower than the A-body rear. Comes on an easily adaptable carrier. Strong.
con: Known handling issues. Not cheap.
5) 200X GTO
pro: Easily adaptable. Inexpensive.
con: Strength (both the differential and the suspension components)?
6) Pontiac G-8
pro: Comes on an easily adaptable carrier.
Remember, this is a bit of a Pro-Grand-Touring car; a backroad burner, long distance tourer, and not an autocross machine.
I was leaning toward the MN12, but after reading about the Jaguar unit, I think it might be a good choice. It even has the right wheel bolt pattern. I think the adaption of a trailing arm to the factory A-body might help with wheel hop?
Anyway, looking for thoughts and arguments regarding any of these.
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 06-10-2012, 11:13 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Check out these links, a bit of info, not real in depth, but a good starting point for research.
http://www.rodandcustommagazine.com/...n/viewall.html
http://www.hotrod.com/howto/hrdp_071...s/viewall.html
Did you consider a C4 Vette Rear end type of set up? The gear case / center section is braced with a torque arm (like a 3-link) and the wheels are set up like a 4-link. Yeah a real oversimplification, but I've heard that most mods that narrow the set up still retain good geometry with a hub to hub measurement as narrow as 58 inches .
These guys do a C4 Vette suspension on 50's trucks and tri-fives
www.hotrodjim.com/trifive_c4_grand_coil.php
And there are a few other shops that do custom C4 Vette set ups. They mostly cater to Corvettes only but some have done other projects.
http://uscorvetteconversions.com/
http://www.progressiveautomotive.com/
And one of the guys in our club has a 69 Camaro with a BMW 7 series IRS. He liked it because it had the huge brakes, and the right hub to hub for his project. He went with cantilever shocks in the trunk. Quite a project but it looks sick, and it handles great.
http://pacificfab.net/barry-camaro.htm
DETONATOR - 69 Camaro RS
Old 06-11-2012, 06:16 AM
The C-4 looks nice, but very pricey.
The more I read though, the more the GTO rear looks like a good choice. Though he's never posted anymore on it, DDT RCKT put one in a a '70-'72 LeMans (shares a frame with my 442). Here is the thread on it.
Hmmm.....
Shiny Side Up!
Bill
