Old 01-28-2010, 12:38 PM
c5denny69's Avatar
c5denny69 c5denny69 is offline
Default Finn's Auto Restoration 69 Concept Camaro
Wanted to share some pic's of our 69 Concept Camaro.
Finns Auto Restoration & Custom. www.finnsautorestoration.com
We are located in Molalla Oregon and have been in business since 1992. Molalla is within an hour of Portland Oregon. We are one of the larger Restoration shops in the State of Oregon. We usually have 15-25 Restorations going on at a time.
Our project is based off of a 69 Camaro that we have redesigned to be more modern inside & out. The drive train is newer Corvette (C5-C6) front & rear suspension, LS7 engine, and 6 speed transaxle.
The Chassis is an Art Morrison Max-G modified by Schroder Speed & Custom to accept the Corvette transaxle & narrow the Corvette rear suspension mounting points. Brembo 15" 6 piston front & 13.5 4 piston rear brakes.
The engine is a GMPP LS7 with a Magnuson TVS2300 supercharger. The engine is being upgraded by Mast Motorsports with their Blower cam & M90 ECM & engine harness. The engine should make over 775hp. Front drive assembly is a Vintage Air front runner.
Sponsors include:
American Auto Wire; hwy 22 kit.
Brembo Brakes; 15" drilled front 6 piston, 13.5 " drilled rear 4 piston mono block.
B&M; ripper shifter
Canton Racing Products; dry sump oil tank.
Cherry Bomb: mufflers, tubing.
The Drive Shaft Shop; custom drive shaft & half shaft (rated 1000hp).
Eddie Motorsports; Billet Hood hinges, tail lights, SS hood louvers, & more.
GMPP Dr Jamie Meier: LS7 crate engine
Goodridge: fluid transfer systems.
Hush Matt; sound deadening & heat resistant materials.
Ididit: aluminum steering column, steering shaft & joints.
Quick Time; C5/ C6 bell housing/ scatter shield.
Racepack: gauge pack.
Recaro; heated & cooled seats.
Ricks Stainless Tanks; custom fuel tank & pump.
Macs Radiator (Portland Oregon); Custom Radiator, heat exchanger for super charger, and aluminum radiator support.
Magnuson Superchargers; TVS 2300 supercharger kit.
Mast Motorsports: Upgrade & dyno tune engine with their M90 ECM, engine harness & blower cam. Thanks guys!
McCleod; RST twin disc clutch (rated 800HP)
Mickey Thomson; SR street radial 29x 18 x 20. 17.25" side wall to side wall (aprox 438mm unmounted)
Percys; laminate side windows.
Schroder Speed & Custom; modify Art Morrison Max G chassis to accept Corvette transaxle & narrow suspension mounting points. Thank you!
Schutt; hand made steering wheel, shift knob, pedal pads.
Super Chev Parts (Portland Oregon); sheet metal, parts, etc.
Vintage Air; Gen 4 heat & A/c system, front runner accessory drive.
Wilwood brakes; remote reservoir master cylinders & pedal assembly.
More info to come. Enjoy, Denny Finn
104 W. Main St.
Molalla Oregon, 97038
(503)829-8488
Old 01-28-2010, 01:49 PM
syborg tt's Avatar
Welcome to the BB pretty cool project you have there.
marty-mj
Old 01-28-2010, 01:50 PM
EddDeeEye EddDeeEye is offline
Sounds like a killer project!
Old 01-28-2010, 04:07 PM
customcam's Avatar
Welcome
Hell of a project your got going! More pics please
Old 01-28-2010, 04:35 PM
MattG's Avatar
MattG MattG is offline
O.K., that's cool, and different (not easily said these days).
Subscribing
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 01-28-2010, 04:44 PM
awr68's Avatar
awr68 awr68 is offline
Thanks for sharing Denny - very cool chassis! I still NEED to get over there!! Been a long time since I've seen the car in your avatar too!
When my car makes it home I will have you and Dave over!
Tony
'68 Camaro
Old 01-28-2010, 05:57 PM
I've been in Mollala... I had my chassis made there at Superior Glass Works... Next time I'm down to pound on Brad - I'll stop by and say hi!
Old 01-28-2010, 06:48 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Good lord look at those rear tires.
Old 01-28-2010, 07:11 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Nice to see some local work on Lat-g
Darryl Schroder does good work, he still at the same shop in Boring?
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 01-28-2010, 11:57 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
no he is in Troutdale now
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
