Old 08-16-2012, 12:39 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Default Gas Tank for LS2 conversion
Hey guys-
Looking to swap an LS2 into my 69 Camaro and I was wondering what is the most economical solution for a gas tank and fuel pump.
Thanks!
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 08-16-2012, 01:43 PM
pw2006's Avatar
pw2006 pw2006 is offline
I bought this one from Ecklers:
http://www.rickscamaros.com/camaro-g...rted-1969.html
I went a different direction and still have this new in the box. I'll sell it for $400 + shipping. How's that for economical!
Rob
69 Camaro PT project- LS3/4L70e, Budnik's, Ridetech, Speedtech, Wilwood, DSE tubs, 4 link, shortened Moser 12 bolt- in progress
Old 08-16-2012, 02:00 PM
gray86hatch gray86hatch is offline
I used the Tanks Inc in dads car and it works perfect. 6000 miles not a issue
Tim
86 mustang
454 lsx FTI ls3 mast 4500 9.24 144 pump gas dragradials
79 z28 29k org miles. DSE suspension Bonspeed GTB
Old 08-16-2012, 08:09 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Im also curious about this, as I plan on swapping in an LS2/3 over the winter hopefully.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 08-26-2012, 01:18 PM
97 Z Me Go 97 Z Me Go is offline
anyone try the new areomotive stealth set up like 600 bucks tank pump and all ready to roll. I was wondering about trying to get one to work on my nova for the price it is a killer deal.
Old 09-10-2012, 06:27 PM
wgearhead67 wgearhead67 is offline
Default anyone use stock tank with sump and inline pump?
Great timing on this question! I plan to put an LS1 in my 67 Camaro this winter, and my definition of economical is generally less than others on forums (read cheap-a$$). I haven't looked much at the fuel side of the swap yet, but I found somebody selling a 69 tank modified with a sump. I've read others using a sumped stock tank with an inline Walbro pump, but I can't find any pictures of the set-up. I understand the Walbro pump needs to be mounted lower than the tank to get the gravity feed from the sump, but when I look on my car, I don't see how to get the pump lower than the tank. The tank already hangs so low.
So can some of you that have done this with success post some pics of how you did it? Thanks!!
Old 09-12-2012, 01:01 PM
rallystyle rallystyle is offline
the areomotive stealth tank is a tanksinc fuel injection tank. they worked together on it.
http://www.tanksinc.com/index.cfm/pa...cat/cat144.htm
1970 El camino
1969 camaro
1996 civic
Old 11-03-2012, 07:40 AM
andrew69_04 andrew69_04 is offline
I used the tanks inc pump setup with the stock tank in our 79 Z28 LS2 build and it has worked out very well so far. Once I get around to building the 69, I will be going the same route.
