Old 05-01-2016, 11:11 AM
kwhizz's Avatar
kwhizz kwhizz is offline
Default Gary's 65 Final Chapter
A little past history of Gary's car........A couple years ago we added Ridetech Coil-over suspension...Disc Brakes.....A/C......Aluminum Radiator and Electric Fans........anticipating the future swap of a LS engine into the car........Well.....The time is here.....Gary ordered a GM connect and cruise set-up........LS3 (480 H.P.) and a 4L70 trans.....
So......Gary pulled the big block out at his house and brought the car over yesterday at 10 am......We swapped out the LS3 pan for a Holley 302-1 pan and some motor mount adaptor plates that I made up to raise the engine slightly to clear the front crossmember.......the car was originally a 6 cyl Powerglide car.....at some time in its past it was converted over to a 454 /turbo 400 car....... and during that swap, there was a second set of trans crossmember mounts welded in for the turbo 400 position......so....we had two sets of mounts on the frame......Works out easy for me as the new set-up uses the rear holes on the front mounts........a little sawzall action and I'll make up a couple small plates tomorrow to fill in the gap between the mounts and the everything is as simple as it can get......anyhow.....by 2 0'clock had the engine in and were finished for the day....
Here are some conversion pics............
Old 05-01-2016, 11:51 AM
Sonar Chief's Avatar
Cool
Here we go again .. I'm in, always learn something with your detailed posts, thanks for sharing. I'm heading down the same path here real shortly, might have some questions .... lol.
Michael
Old 05-01-2016, 02:54 PM
Swap Master!
Old 05-03-2016, 04:58 AM
kwhizz's Avatar
After getting the engine and trans in we checked for clearance issues with the trans........had only one spot that need a little massaging.........pulled the engine out and fixed the clearance issue correctly......and before putting the engine in for the final time.......we installed the wiring harnesses.........LOL.....I had a plug for the MAP sensor that didn't fit.......after a while I called Pace Performance where the engine came from and talked to a Tech guy..........I explained the problem.......His response was classic........"Did you read the Instructions"..........then added....."look in the Envelope in the box for the adaptor harness"...........Duhhh!!!..................Anyho w we got it back in with all the wires and then installed the Kwik Performance front drive set-up.......Moving along
Old 05-06-2016, 04:46 AM
kwhizz's Avatar
Update..............Got a lot of little Important things done.........Fuel system, all engine mounts in and ready to go......got the control modules and fuse panel installed.......(notice all the wires are almost gone).......some of the old wires are still in place and will be removed as required.....Driveshaft was shortened a couple inches.....the Air Intake system will be finished today along with mounting the DBW gas pedal.........Getting closer
Old 05-07-2016, 02:58 PM
kwhizz's Avatar
One week of just a couple hours a day........Here we are......Got the air intake system completed.....Had to find a new spot to mount the Power Steering reservoir as the inlet tube needed the space.....Got that resolved......hooked up the starter wires and spun the engine over.....Ordered fittings for the transmission cooler lines where they come out of the trans........Wanted to get that completed, but.....I guess I ordered the wrong fittings as they didn't fit........Darn.....We also got the correct Serpentine belt installed along with the Radiator.........Also got the gas pedal installed and plugged in...Getting closer.....
Old 05-07-2016, 03:36 PM
dhutton dhutton is offline
I just went through the same thing on 4L65E transmission cooler lines. Ordered 1/4 NPS adaptors but they did not fit. Figured out they were 9/16 ORB (o-ring) fittings. Got some adaptors and they fit great.
Old 05-07-2016, 05:30 PM
Cool Question!
Are you guys talking about the adapters from GM quick connect to -AN fittings?
I read the March Super Chevy article about the LS into the Chevelle, they got them from Sweet Performance, are there other vendors?
Ken ... this is good info and I'm taking notes, thanks for sharing!
Michael
Old 05-07-2016, 06:36 PM
Michael
Going LS now?
Old 05-07-2016, 06:41 PM
Michael
The Sweet adapters are 1/4 NPS. They might work for a 4L60E but they did not work for my 4L65E.
