Old 07-30-2013, 11:16 AM
BANKO's Avatar
BANKO BANKO is offline
Default Improved bleed screws for PBR/Z06 & Wilwood W6a Calipers
I've noticed the PBR bleed screws are a bit short and make it difficult to use a vacuum bleeder. I've also talked to friends who mentioned the Wilwood bleed screws are quite small making the brake bleed process difficult. Got any tips on replacing this bleed screws prior to the caliper install.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 07-30-2013, 09:42 PM
You can use a bleeder you just have to have the right adapter nipple.
