Old 09-03-2013, 10:16 PM
jimboR831 jimboR831 is offline
Default 2" drop drum spindles
So I ran into a bit of a dilema. I'm using ls1 brakes up front on my 67 camaro and for those to work I have to use a drum spindle. I want to get a 2" drop spindle but it appears no one makes drop drum spindles. Any ideas guys
Old 09-03-2013, 10:39 PM
David Pozzi's Avatar
just add a spacer to the top bolt. Many brake kits come with the spacer. It should be around .610" thick.
http://www.PozziRacing.com
Old 09-04-2013, 12:53 PM
Ok thanks but will the disc spindles work with the drum hubs?
Old 09-19-2013, 11:46 PM
Yes it will work the same as a drum spindle.
