Old 09-24-2013, 09:23 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default Centerforce DFX or Dual Friction please chime in
Wondering if the DFX will be to aggressive or have to much chatter. Application is a 600+hp supercharged Gen1 383, LT t56, Detroit 4.11's,
335's in a Gen II Camaro.
Some road race/drag/autoX but it will be driven on the street a lot.
Thanks in advance for any input.
(I've asked for opinions before but I'm getting ready to drop the hammer and want to make sure. Sorry for being repetitive.)
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 09-24-2013, 10:17 AM
67ragtp 67ragtp is offline
Ive used them both, the DFX will chatter your teeth, I wouldn't recommend it on the street very harsh on engagement.
The dual friction is a decent clutch might just be outside your power requirement, if you decide on this one explore the possibility of fitting a 12 inch pressure plate for more clamping force. I believe it will fit.
I love my DYAD, never chatters, has great street manners and enough grip to hold my motor and yours combined.
Mcleod rst/rxt is a good piece as well.
Rich
Old 09-24-2013, 10:36 AM
NorCal72's Avatar
Rich
That's the issue, with my Gen I SBC/LT1 conversion flywheel I have to run the LT1 clutch setup. Centerforce doesn't make DYAD for my application, McLeod doesn't make a RST/RXT option either. The Centerforce dual friction seems to be the best option. However, I agree with you on the power being a bit too much for that clutch. I've looked at the SPEC Stage 3+ as well but I've read a lot of mixed reviews. So confused LOL
Old 09-24-2013, 12:33 PM
Give the guys at centerforce a call. I Think you will be ok with the Dual friction. I ran it on a 540 cu in, Mitchell BB making near 700 ft lbs. It performed great, it wasn't until I made 5 passes with a set of Hooser QTPs hooking hard at the drag strip that I started smelling friction material. Real nice on the street, you more than likely will blaze your tires which takes a significant load off the drivetrain(clutch). Even the 335 r888s on my camaro with 500+ rear wheel blaze 1st and 2nd gear effortlessly, its just not as much impact on the drivetrain when the tires spinning.
Good luck- Rich
Old 09-24-2013, 11:01 PM
funcars funcars is offline
I was on the edge and slipped occasionally running a dual friction with my 90 corvette and a 400 roller cam motor with 315 R tires. With even more torque and sticky tires I would think you stand a good risk.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 09-24-2013, 11:26 PM
NorCal72's Avatar
More conflicting, but great info. Im totally undecided on which way to go. Thanks for the replies.
Old 09-28-2013, 03:04 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Guys, I'm partial to the RAM dual clutch disks. I ran one with my BBC 509 about 8 years ago. What's you all's opinions on RAM clutches? I always see lots of guys on here mention and run the DYAD, but not many RAM's. Although pricey, I loved them and plan to run one with my 427 supercharged LS7. Do guys not like RAM clutches or what?
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 09-28-2013, 11:15 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
I have 79 Z-28 Camaro with 500 plus Supercharged small block Chevy.with a Center Force Dual Friction clutch /Super T-10 / Lakewood Scatter Shield Combo.And I have never had such a problem. Are you running a Scatter Shield.and its not aligned properly It could cause such a problem. I would also ask them for advice as well.
Old 09-29-2013, 08:02 AM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
My tips would be that, whatever clutch you choose, if you are gonna use it on the STREET, Select one With springs, or some sort of damping. The springs helps a lot on "smooth" engaging. On what clutch is better or worse, I do not know.
But 600+ Blown HP, plus Good Grip in a second gen (Heavy car?) would probably need a stout clutch.
Old 09-29-2013, 11:34 AM
NorCal72's Avatar
I've seen people that swear by them and others that have nothing good to say. I've not seen much negative press about RST/RXT, DYAD, Dual Friction except the Dual Friction cant handle huge HP numbers.
Being that I have use a LT clutch Im still screwed. They don't make a RST/RXT or DYAD for the LT. I think the Dual Friction Centerforce will come up a bit short. Nothing against a RAM I just need to hear some feedback on a 6-700hp (depending on boost) application and what model they are using (I need to be somewhat streetable)
