Old 02-12-2014, 04:52 AM
71RS/SS396's Avatar
Default Baer's Latest Rotor
I just bought Baer's new R-spec floating rotor
Old 02-12-2014, 05:17 AM
Bryce Bryce is offline
I like the floating radial mount
Old 02-12-2014, 12:25 PM
carbuff's Avatar
carbuff carbuff is offline
Are these designed to try and eliminate the need for a floating-style rear end by allowing the rotor to float on the hat, instead of the more complicated traditional floater rear?
Old 02-12-2014, 12:32 PM
71RS/SS396's Avatar
I'm using them on the front. My understanding is that it will improve the braking performance by keeping keeping the rotor centered better, they are a little lighter than the standard rotor as well.
Old 02-12-2014, 07:02 PM
Rod P's Avatar
Rod P Rod P is offline
those are SWEET!!!
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-15-2014, 08:06 AM
Solid LT1 Solid LT1 is offline
No! The rotor and mounting hat pictured are what is referred to as " radial mount " in that the rotor to hat mounting system allows for radial movement that will be caused by operating in high heat conditions. Because the mounting points are not captured but in a radial slot the mounts can actually move outboard to a bigger diameter when they expand due to being extremely heated. Conventional rotors and hats with fixed bolt circles can crack and fail at the mounting points due to the forces of extreme heating.
The floating rotors your thinking about are generally used on motorcycles with small caliper piston bores/thin friction material pads and won't work well in a automotive application because of the use of thick friction materials/bigger piston diameters used. Think about it, pads are 1/2 worn through 1/8" or better and the rotor is rattling around knocking the pistons back into the caliper bores.....heading into a high speed braking point into a tight turn.....go for the brakes.....pedal sinks almost to the floor before the brakes respond.....not something you want to have happen....will happen with poor wheel bearing maintenance too....or excessive rotor runout.
Last item.....a " floating rear axel " the word float....only refers to the axel shafts which float between the differential and the outer hub assemblies this allows for safety in the event of a complete breakage of a drive axel, everything stays in place and the event is usually only felt because the car suddenly wants to drive in the direction of the broken axel ( type of locking differential used can greatly effect this tendency )...the snap of a rear axel can be quite a life changing moment in the middle of a high speed banked turn
Old 02-15-2014, 09:05 AM
Don't confuse a "full or semi" floating rear end -- with Full floater brakes....
Old 02-15-2014, 09:00 PM
carbuff's Avatar
Thanx for the explanation, it helped. I understand the full-floater rear end concept, what I didn't get was that the rotor/hat in this part was set up to 'float' in the radial direction. That wasn't obvious to me from the couple of pictures I have seen, but your explanation made it clear.
I'm actually contemplating changing my rear axle setup to use the Baer floater setup. I already have their rear Extreme kit, so I just need the adapter/hub kit. I haven't priced it yet, but since we are going to have to pull the rear housing to resolve a couple of leaks around some welds, that might be a good time for the swap. It will likely come down to whether we can get it done in the 3 weeks between events that I have or not. May have to wait until late March after the FW GG...
Old 02-16-2014, 08:02 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
The more you track the car, the happier you will be with the floater rear. You can even get away with minimal amount of camber and toe if you want.
Old 02-16-2014, 05:41 PM
carbuff's Avatar
Does anyone know how Baer handles the axles for their floater kit? Do you have to take measurements and then contact them to special order them? I would expect every setup to be different. If so, what kind of lead time does they have?
Thanx!
