Old 10-10-2016, 12:19 PM
70UglyBird 70UglyBird is offline
Default Converting a Terminator EFI to HP EFI lsx
Posted this in Pro Touring too not
So I am in the process of part gathering for my LSX swap. Have quite a bit but still have a bit to go.... Would love to get the car with the Pontiac running right for next summer and not waste a bunch of money doing so. My biggest problem is the Holley 850 and my ignorance of it... So was thinking of doing a ricks tank and Terminator EFI. I know the Terminator ECU is the same as the HP for LSx. This way I have the ECU installed, wired, return line, II Much vent etc ready to go for the LSx.
So could I get the terminator for now and buy the ls1 and injector harness and convert it when the time is right?
Figure I could sell the TB for a couple of hundred to offset the cost. I've tried calling Holley but each time they say it is an hour wait time so call back later.
Thanks!
Old 10-10-2016, 03:46 PM
andrewb70's Avatar
Yes. You may need to but the LS harness eventually as well, unless you want to modify the harness that comes with the Terminator. Personally I would just get a new harness, plug it into the HP ECU and run your LS...
Andrew
Old 10-10-2016, 04:29 PM
That's perfect I get that I'm going to be losing some money....but being able finally have a fun summer DRIVING through car is worth it! I just don't want to be doing everything twice if I can.
Looks like I need to post my gm computer and standalone ls harness in the for sale section!
Thanks!
Old 12-26-2016, 06:03 PM
64duece 64duece is offline
I did an LSx Terminator conversion several yeas ago. In this particular case, we added the LSx coils and cam/crank inputs. We also added the remaining I/O which is not populated in the Terminator harness. If you have specific questions, ask away.
Dennis
Moore Racecraft
Old 12-27-2016, 07:35 AM
hifi875's Avatar
hifi875 hifi875 is offline
I have a terminator and wanting/thinking about doing ls intake/tb conversion as well. Is there really any performance advantage to doing this. I like my old school look and most poeple think its a carb when they see it.
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 12-27-2016, 02:41 PM
I've done early small and big block TBI to MPFI conversions and have noted some power gain however, part is attributed to the "swapped over" manifold design. If your current manifold offers good distribution, I'd bet the conversion will net only marginal gains. Couple that with you linking of the "old school" look and I'd say your dough is probably better spent elsewhere.
Dennis
Moore Racecraft
