Old 04-10-2015, 09:32 PM
gearheads78's Avatar
Default Lets talk belt grinders / Disc grinders / Bead rollers
So my twins are now almost 4 so they are old enough to play and little on there own so I see myself finally finshing out the shop I started putting together 5 years ago. Need to collect a few more big pieces of my puzzle. The next two big items are a bead roller and new grinder. I am pretty sure the bead roller is going to be the Mitler Bros 36" high throat model with industrial motor. Opinons on that?
Where I am struggling in the grinder(s) I currently have the stand up JET combo model I spent $800 7 years ago on and hate it. I push even a little hard and I stop the damn thing in it tracks. I'll sell it a step up probably to a Burr King but which one? There are so many widths belts , 2 wheel or 3 wheel, fixed speed or variable speed??? I want to do this one more time and will it to my now 3yo son if he grows up in to cars like I think he will. Also do need a disc grinder. I use it as much as the belt now but will a good belt be enough? Any other models or brand I will be just as happy with?
Lets hear it what do you have or what do you wish you would have got?
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
Old 04-10-2015, 11:16 PM
I have the Mitler bead roller. If I had to do it again I'd go with the Baleigh. It has more features and accesories.
In this field the disc isn't used much. Well in my shop it isn't. If it isn't bigger than 12" I feel it puts too much heat into the metal. I use my 2 in sander disc and angle grinder the most. Choose a wider belt and one that uses a common size belt. Choose the tool for the job. Look back and think of the jobs you have done where you would need one.
Old 04-11-2015, 06:08 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Made me curious, I immediately went over to the Baleigh site and looked around, what features and stuff do they have over Mittler?
(I've got the Mittler also BTW. I've noticed since they hooked up with Jamey Jordan, they've been adding all sorts of accessories to their line but hands down the most gizmo award goes to Lazze.)
Old 04-11-2015, 12:53 PM
Is Baleigh not just rebranded other people stuff? I see a belt sander on thier site identical in every way to the junk JET one I already have. Only difference I see is paint color and $400 higher price.
Richard J.
Old 04-11-2015, 02:18 PM
FlameBroiled's Avatar
FlameBroiled FlameBroiled is offline
I have one of these sanders, seems to work pretty good!!! Just watch your fingers!!
http://www.general.ca/products/1_gen...er/15-015.html
www.Eyekandykustoms.com
Old 04-11-2015, 04:59 PM
70 chevelle 70 chevelle is offline
I'm pretty sure he was referring to the higher end Baileigh. I have the Mittler and love it but the baileigh is VERY nice. It has a lever action and allows repositioning without unscrewing tension every time. tried to post a link but it isn't working. It's model number BR-16E-36
Tony L
You can't fix stupid!
Old 04-11-2015, 10:14 PM
Does look like a nice machine but if I was going to spend that much (and I can't) I would buy the Lazze one.
Richard J.
Old 04-12-2015, 07:58 AM
gerno's Avatar
gerno gerno is offline
I've been thinking about both a belt grinder and a bead roller but haven't pulled the trigger. I'm interested to hear more from others too. The most critical tool is the belt grinder. I was thinking to possibly do one of the DIY kits like the knife makers do. A like to an example is below. Anyone ever built and used one of these??
https://www.youtube.com/watch?v=E3tCPDh67Oc
Old 04-14-2015, 12:08 PM
Graham08's Avatar
Graham08 Graham08 is offline
I have a Kalamazoo 2" x 48" belt grinder that I like quite a bit. It has a 1/2 HP Baldor motor on it. I use it mostly to tune up stuff that was cut on my bandsaw. It is not a Burr King, but cost a few hundred instead of a few thousand.
I have a Pro-Tools bead roller. They used to offer a kit that you welded yourself, which is what mine was made from. If I had it to do over, I would probably buy a Mittler Bros. The Pro-Tools machine can use the MB dies. The PT machine is OK, but the MB stuff is just a little nicer all around, plus their frame is quite a bit stiffer.
Old 04-14-2015, 03:00 PM
Thanks for your input.
Richard J.
