Closed Thread
Old 11-25-2014, 10:00 PM
Carbo Carbo is offline
Default SBC 408 with front accessories and Ignition
Item Location (City/State):Las Vegas, NV
Price:$4400.00
Description:SBC 408 Engine with Accessories and Ignition.
For sale is a 408 Cubic Inch SBC engine. It’s an 88-92 350 roller block that has been bored and stroked. I am selling because of a pending LS Swap. The engine is currently in the vehicle and will not be pulled until it is sold. So if you are serious about the engine you can still here it run. I am located in Las Vegas so for you eastern guys this is a good excuse as any to come to Vegas....
The following is a list of the parts in the engine:
GM 4 bolt block
4.00 stroke 4340 forged steel crank
4340 6” H beam rods
Mahle forged pistons
Mahle file fit rings
Dura-bond cam bearings
Comp Solid roller cam, Part # 12-705-8, Grind # CS300A-R10
Cloyes Double Roller Adjustable timing set
Cloyes Aluminum Quick Button Timing Cover
Melling High volume oil pump and drive shaft
PBM Solid Roller Lifters
Dart Pro 1 Aluminum Heads with 2.02 Intake/1.60 Exhaust
Comp cam push rods
Comp Ultra Magnum steel double roller rockers
Edelbrock RPM Air Gap Manifold
AED 750 CFM double pumper carburetor
Pertronix Flamethrower distributor.
The engine dynoed at 520 HP / 518 TQ at the crank. This engine is very strong and will spin the tires through second gear with a 342 rear end. The engine is installed in a 69 Camaro and only has approximately 5100 miles on it. Included with the engine is the the MSD 6al ignition box, the MSD Blaster coil, the starter and the front drive accessories. So all you have to do is drop it in your car. I can be reached at 702-712-7934 for any questions you might have.
$ 4400.00 + shipping
I'm only able to attach one photo so if you want to see more just PM me your email and I'll send you additional photos.
Old 12-28-2014, 09:07 PM
I'm open to offers.
Old 12-30-2014, 03:39 PM
harley-jm harley-jm is offline
Default 406 motor
pm sent
thanks
Old 12-30-2014, 05:35 PM
PM replied.
Old 01-01-2015, 03:31 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
That is one Bada** SBC
Old 01-01-2015, 04:17 PM
Thanks John. I have a feeling it will be selling soon.
Old 01-01-2015, 05:05 PM
Vega$69's Avatar
Can hardy wait to see the LSX dropping in.
Old 01-01-2015, 06:52 PM
You and me both!!!!
Old 01-09-2015, 09:50 PM
Sold to harley-jm. Thanks to Paul and Lateral-g.
Closed Thread
