Thanks!
I realized it takes guts or cluelessness to post any car other than a first-gen Camaro here, but just reading the Ron Sutton stickies felt like a good reason to join. I have an '86 Camaro, and have had a '71, so maybe I won't get ejected
This RX-7 is getting the V6 engine from a '96 Camaro, the T5 from a '94 Camaro, the 7.5" axle from a '94 S-Blazer, because of a 2.29:1 axle ratio being installed.
This isn't my car, or I'd have the paint wait until after the mechanicals. The owner wants an occasional daily driver, and mostly a road trip car. So the primary goal is the capability of 50 MPG. Can't enjoy your touring if you can't afford it, right? To that end, it will be 1536 RPM at 65 MPH, and there's 2.41:1 gears if it needs more. Otherwise, I may go hunting the mythical 2.14:1 gears.
This T5 has a 3.75:1 first, and a 0.72;1 fifth. There's always the 4.03 / 0.76 set if needed, or going the other way, a 3.35 / 0.68 set.
Not much progress to show until the car returns from paint and a new windshield. I really don't like these particular exhaust manifolds, so I hope they don't fit. But I'm not changing the cam anytime soon, nor rockers, nor porting. 205 HP should suffice. I'm keeping it ULEV, because why not?
Others have made stock shifters work, I wish the B&M was in the plans.
I'll be fabbing a belly tray, I'll eventuall try both an airdam, then a rear spoiler, then both, all in the hunt for the MPG.
The rear brakes are from an '84 Trans Am I had, I re-drilled those rotors to fit '89 Mustang shafts. Now it all bolts together with the Auburn posi from a '94 Z28 that had the standard 2.73s.
Audio is simple: a brand new new, direct from Pioneer AM / FM head unit that plays old cassette tapes, plus a used Alpine 6-disc CD changer off E-Bay, and 4 new Pioneer 3-way speakers. That's it. No woofers, no subs, no bluetooth / satellite / I-pod / whatever the kids do now.
The tan interior got dyed gray, it turned out well. The new paint should be Navy blue. Seat covers will be custom.
I test-installed the gauges from a '94 Camaro, not bad, but needs work.
I sent the PCM to Ryan Gick at GMTuners.com, he's done well for me before.
The wheels were ordered before I knew about the front suspension swap, but the owner's desire for power steering sealed the deal. So now it is stuck with 195/55R15s on 15x7s. These particular wheels should allow 12.46" rotors with Evo 9 sourced Brembo 4-piston calipers up front, come spring. Partly because it will need inch thick adapters, to match the rear track, and for these high-offset wheels with smaller lug circles. I've seen how GM had 11.88" rotors inside steel 15s. Like a '77 police Caprice. So I measured the backs / insides of these.
So that's all for now.
