Old 03-25-2015, 07:56 PM
jblaine86 jblaine86 is offline
Default TKO 600 neutral safety switch
Was thinking of using the built in neutral safety switch on my tko 600. I have heard I have to use a relay but not sure witch one. Can someone help me with this?
Jon
Old 03-25-2015, 10:18 PM
Jon
Just your standard 30amp Bosch relay.
I now use the trans switch to ground the circuit. Alot less wiring down to the trans.
Heres the IGN side schematic.
Old 03-26-2015, 07:44 AM
badazz81z28 badazz81z28 is offline
I used the switch built in the trans too and plan to use the t56s as well. Makes the wiring much simpler
Old 03-26-2015, 08:00 AM
Thanks for the responses
