Old 04-15-2015, 10:10 AM
JohnUlaszek JohnUlaszek is offline
Default NEW -- IIMuch Airport AC Bulkhead System
The II MUCH Airport AC bulkhead was designed to dramatically reduce the effort required to route EZ-Clip lines through the firewall when installing Vintage Air AC systems.
All four lines fit through a 2.5" hole
Because fittings are eliminated there is no need to allow for wrench clearance
With EZ-Clips tight bend radius packaging options are improved.
Hoses can be passed through without removing hose ends
Airport seals against the outside diameter of the EZ-Clip hoses
Includes an adapter for the heater control valve to adapt form EZ-Clip to heater hose
O-Ring interface seals against the firewall
Anodized 6061-T6 Aluminum
