Old 07-21-2015, 09:13 AM
72Greencamaro 72Greencamaro is offline
Default Has anyone used a splined sway bar on their second gen camaro
Sorry if this is a repost.
Im wanting to do a splined sway bar up front on my 72 Camaro for more clearence to run 315,s up front. Has anyone done this yet?
Old 07-21-2015, 09:15 AM
DB Z28 DB Z28 is offline
I was wondering the same thing
Old 07-21-2015, 04:55 PM
Blake Foster's Avatar
I don't know of one that would fit a stock subframe and 315 tires ?? but I know our new sub frame has one and we have 6 different rates from 530 to 1200 lb.
Blake Foster
www.speedtechperformance.com
Old 07-21-2015, 05:57 PM
I looked on your website and did not see a sub frame for a second gen. That being said I would be interested in the details, and are you looking for a test car?
Old 07-22-2015, 12:34 AM
https://lateral-g.net/forums/showthread.php4?t=49545
We have a 295 on an 11 but 315's would be a stretch. Fender stretch, modified or no inner well.
Old 07-22-2015, 08:09 AM
I was either going to use the anvil carbon tubs or fab and bead roll some inner wells. My big concern is sway bar clearance. I have 275 up front now and they rub the sway bar when turned tight.
Old 07-22-2015, 08:45 AM
If the model is close to reality then we have clearance with a 11" rim with 8" of backspace and 30 deg of steering.
I will have a finished second and first gen sub here next week to try all the "Theory". The first and second are identical except for mounting locations. The second gen being wider at the fenders may allow for an even larger tire??? you will be the first to know!
Blake Foster
Old 07-22-2015, 09:13 AM
Rod P's Avatar
Rod P Rod P is offline
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 07-22-2015, 12:24 PM
well in that case yes.
we moved the sway bar down and forward using a speedway bar
Old 07-22-2015, 12:25 PM
also loving this.
