Old 04-17-2015, 10:57 PM
canrc canrc is offline
Default Fuel Pump Help
I am replacing the fuel pump in my car, I was going to switch to the dual ZL1 pumps but don't want to buy another tank at this time. I have had a couple that I have narrowed it down to but am open to suggestions and help.
1 - Walbro 416
2 - Dual 044 Bosch Pumps
Any help is appreciated!
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 04-18-2015, 12:34 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
1 - Walbro 416
Raj,
I had a Rick's tank built for 2 (Dual 044 Bosch pumps). I could probably sell this fuel tank to you, if you want it. I can have one built for dual ZL-1's. My Rick's tank was built for a 1969 Camaro, but we modified my tailpanel on my 67 Camaro.
Jeff
Old 04-18-2015, 02:07 PM
Thanks Jeff but I have an off ball tank size do to the AM Chassis.
However I am thinking of going with external dual 044's, just am not sure that having them external will cause any problems -- I will continue to run the pump controller with them also.
- Raj
Old 04-18-2015, 06:44 PM
Sparks67's Avatar
You can try an Aeromotive A1000. I tested mine with one of those pumps, and it ran fine. My Bosch 044 are internal pumps.
Jeff
Old 04-18-2015, 07:00 PM
supremeefi supremeefi is offline
Good stuff.
http://www.aemelectronics.com/?q=pro...low-fuel-pumps
Mark
Engine builder and tuner.
Old 05-01-2015, 11:43 PM
Well ended up going to a new tank from ricks with the same setup as Mr Stielow!
- Raj
Old 03-13-2016, 07:22 PM
elwaupo elwaupo is offline
Originally Posted by Sparks67 View Post
Raj,
Jeff
Hmm, I might interested in that tank if the price is right
Old 03-13-2016, 07:30 PM
Che70velle's Avatar
Here ya go...
https://lateral-g.net/forums/showthread.php4?t=50573
Thanks Dad!!
