Old 07-24-2016, 11:40 PM
sd67 sd67 is offline
Default Safe Muffler Distance from Gas Tank?
Considering running mufflers close to the fuel tank on a custom chassis 67 Camaro build. What would be a safe distance? Same as the exhaust pipe? Thanks for the help in advance.
Old 08-16-2016, 08:41 AM
Flowmaster Exhaust's Avatar
Flowmaster Exhaust Flowmaster Exhaust is offline
If heat is a concern, you are probably going to want to keep your mufflers a minimum of 3-4" away from the tank. Ceramic coating your mufflers will drastically reduce the amount of heat transferred and applying heat reflecting material to the tank itself may also be an option to consider.
Old 08-16-2016, 10:42 PM
Thanks for the response, good call on the coating, will plan on doing that.
