Old 01-30-2016, 05:14 PM
Efi69Cam Efi69Cam is offline
Default LS conversion VA heater plumbing
I know this has been addressed before, but I'm wondering what the consensus is in terms of maintaining flow through the heater core loop when the heat is off. Basically are you using a flow through type shut off valve or the VA supplied washing machine valve that stops all flow?
Old 01-30-2016, 06:50 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
VA valve. If not you'll get heat 100% of the time.
Old 01-30-2016, 09:02 PM
I got that. The question is use a valve that shunts the water flow away from the core, or one that just shuts it off.
Old 01-31-2016, 06:26 AM
Vega$69's Avatar
Shunts it to where?
Old 01-31-2016, 07:48 AM
Back to the water pump, bypassing the core. E.g. 4 vs 2 port heater control valve. Many OEM applications use the 4 port when flow through the heater core ports is desired. I thought I heard that the LS engines require flow for proper thermostat function.
Old 01-31-2016, 09:01 AM
kevin_l's Avatar
kevin_l kevin_l is offline
I am in the process of installing my LS with vintage air too. This has been a concern of mine also. From what I read on other forums people haven't been having trouble. But I am interested to hear what you come up with.
Old 01-31-2016, 09:05 AM
kevin_l's Avatar
Shunts it to where?
I think he means we've always been told not to block off flow from the ls water pump. Most people who don't run heat have to loop the water pump inlet and outlets heater ports. The vintage air heater block off valve effectively blocks the heater flow. Some late model cars have a by pass when the heater is off but I haven't seen people use them. Like I said I am very interested to hear what you guys think on the matter. This is my first big build and I am always learning something new!
Old 01-31-2016, 10:25 AM
Vega$69's Avatar
I've done 5 LS cars with VA valve. All have worked fine and continue to work to this day.
