Old 06-24-2017, 01:47 PM
Larry R's Avatar
Larry R Larry R is offline
Default PWM for fans, will this work?
I am wanting to power and control my two Spal fans from my Holley HP ECU via a PWM controller (the Ford Fusion version) and have come up with a plan. I know this has been discussed at length in another post bout I would like to get some opinions as to whether or not this will work. Pictured below is a schematic I have hand drawn and a photo of what I have set up in the input/output of the ECU.
Old 06-26-2017, 09:06 PM
andrewb70's Avatar
I don't see why not. If I had AC I would use CTS and AC pressure as well.
Andrew
Old 06-27-2017, 12:03 PM
Larry R's Avatar
Andrew
Thank you. Larry
Old 06-29-2017, 08:57 AM
andrewb70's Avatar
Larry,
I just looked at the schematic again, and I would add a 40amp breaker between the battery 12v+ and the fan controller.
Andrew
Old 06-30-2017, 04:45 PM
Larry R's Avatar
Larry,
Andrew
Ok, I will. Thanks for your help. Larry
Old 06-30-2017, 08:07 PM
Great time for this question, thanks for posting.
Old 07-01-2017, 01:51 PM
Jr's Avatar
Jr Jr is offline
Why do you prefer the ford pwm over the Chevy? Is one that much better than the other?
Old 07-01-2017, 03:00 PM
Larry R's Avatar
To the best of my knowledge, they are identical. I avoided the "Corvette tax" by purchasing my Ford Fusion units new off eBay, so my motive in getting the Ford modules was cost.
That said, when I hooked mine up today, including the 40 amp breaker, as soon as I connected the ground wire to the PWM, the fans came on. This is with the cold engine not running and the key off. I cannot yet say it is the fault of the PWM module or a wiring error, more research is necessary.
I hope Andrewb70 will step in here. Larry
Old 07-01-2017, 05:47 PM
Larry R's Avatar
UPDATE!!! It works! After I fixed the wires I had inadvertently crossed, it works as advertised. My schematic is good. The fans came on as I had set them up in the input/output section of the ECU. I ran the A/C and it still maintained the prescribed temperature. My thanks to all who offered help and encouragement to me in this project. I will take it our for a freeway cruise soon to give it a real test.
Old 07-01-2017, 08:50 PM
carbuff's Avatar
carbuff carbuff is offline
For anyone that may want to do this in the future, do you have the part number for the controller you used?
