Old 10-19-2017, 07:13 PM
1968ls2fisher 1968ls2fisher is offline
Default Engine will fire than shut off
What's up guys I have a ls2/t56 magnum swap I'm finishing up. I have the motor installed and most of the wire connected. I'm running a reworked stock harness. With 2 12v ignition wires 1 12v constant wire. I'm getting the 12v ignition from the fuse panel under the dash. And the 12v constant im gettingstraight from battery. The engine fires for few seconds and than dies. Any suggestions on what it might be and things I can check on. Thanks.
Old 10-19-2017, 08:07 PM
Does it have FUEL??
You might be getting cold start fuel and then nothing more....
To check this -- try having someone spray some starting fluid at the intake when it fires off.... if it keeps running - it's a fuel issue - if not - you have electrical issues.
Old 10-20-2017, 03:46 AM
TomM's Avatar
TomM TomM is offline
Have you had the VATS removed from the PCM? Sounds like this might be a contributing factor.....
T
Old 10-20-2017, 04:47 AM
cpd004's Avatar
cpd004 cpd004 is offline
Could be that your fuel relay only has 12v at crank and not at both crank and run.
1971 Firebird
2017 SS
Old 10-20-2017, 09:21 AM
I know that there's fuel at ignition. I can hear the fuel pump turn on. After crank not sure if there is still fuel. And the Vats should have been removed. Going to check fuel relay later today. Thanks guys.
Old 10-20-2017, 09:22 AM
Should just be able to check the fuel pressure gauge......
68EFIvert 68EFIvert is offline
T
Mine did the same thing and it was the VATS.
