Closed Thread
Old 10-18-2017, 09:23 AM
Try2paz's Avatar
Try2paz Try2paz is offline
Default 1966 Mustang Fastback Street / Track Car
Item Location (City/State):Livermore, Ca
NEW PRICE $65,000
Description:
Car was assembled by Mike Maier of Livermore, CA and Motor and Transmission by Elliot of Mustang Corral in Grass Valley. Both shops know the car very well and would be able to speak to the build.
I've scanned a stack of receipts and I'm waiting on the receipt from Wine Country motorsports for the seats, and Ron for the Race Pack and Budnick for the wheels otherwise I have all receipts. I'm well over 120K, closer to 130k into the car.
I recently spent 30k in the Motor / Trans and new shock towers.
Buy today and be running with NorCal Shelby
The car is built to run Cam-T SCCA (200 TW tire, full interior) 3200lb weight.
Engine & Trans
Brand New Engine only tuning and Dyno time. Just ran on RPM Dyno out of Santa Rosa car made 440HP to the tires. I've got two sets of carbs to go with the car depending on use.
Motor Built by Elliot at Mustang Corral
Motor Details:
410 - Dart Block
Scat Forged assembly
AFR Heads (10:5:1) Comp (91 Oct / 100 Oct shake for track)
Comp Cams
Victor JR intake
Holley 830 (Nascar Carb)
Hooker Headers, 3" exhaust and 20" Billy Boat Mufflers (Will pass sound at Laguna)
4 Speed Top Loader - Fresh Rebuild by Mustang Corral with motor
Centerforce Dual Disk Clutch Assembly
Front Suspension
MMi MOD1 Coilover Kit (Single adjustable JRi shocks)
MMI Lower Control Arms and Strut Rods
1 1/8" Front Sway Bar
70-73 Mustang Front Spindles
New 1967 Shock Towers (Slim) for the big headers.
Wilwood Superlite 6 Front Brake Kit (13" Rotors) (Thermlock pistons)
Wilwood Superlite 4 Rear Brake Kit (12.88" Rear Rotors) (Thermlock pistons)
Stainless Steel Soft Lines
Wilwood 1" Master Cylinder
Proportioning Valve
Steering
KRC Power Steering Pump
CJR Remote Reservior
C&R Racing Liquid-Liquid Power Steering Cooler
ABS 14:1 Steering Box
Woodward Column (Adjustable)
Momo Wheel & Quick Release
Chassis Stiffening
MMI Custom Shock Tower Brace
MMI Subframe Connectors
Rear Suspension
MMI Panhard Rod Kit
MMI 200# Leaf Springs
MMi 1/2" Rear Sway Bar
MMI Drivers Side Spring Plate
Bilstein Rear Shocks
Rear End (9")
31 Spline axels (strange)
race locker with 42lb spring setup
3:55 Motive gear set
Axel tubes Inner seals
Electrical
Coach Wiring Kit
Fully rewired car in early 2016 by MMI
Racepack Dash IQ3 Data Logger
Wideband O2 Sensor / Fuel Pressure / Oil Temp / Oil Pressure / Water Temp
Full track overlay / telemetry / lap times etc
Chassis
4 Point Shelby Roll Cage
Sparco Seats (Setup for taller driver) (Lowered and moved aft)
Fire System
Cabin Proportioning Valve
6 point Scroth Belts
MMI Custom starter/turn signal pod
All new door panels, carpet, mirrors
Link to Album of Photos
https://www.flickr.com/gp/157435809@N08/a5b977
NCSC3452_zpsylubtdxg by Nathan Hall, on Flickr
9E32491C-5D99-4A34-9549-57A60F705DFE_zps66mwt0fk by Nathan Hall, on Flickr
1967 Nova
2018 Camaro ZL1 1LE
Old 10-18-2017, 09:12 PM
Sieg's Avatar
Sieg Sieg is offline
Having track time and experience with the owner and car...... This car is very well cared for by a passionate and meticulous owner. Sadly, having a young family there are times that one's priorities must over rule passion.
If you're interested in an early Mustang track car take a serious look as this one.
Old 10-22-2017, 11:32 AM
gnx7's Avatar
gnx7 gnx7 is offline
bummer.... at least you still have the white Nova
Old 10-23-2017, 02:12 PM
Try2paz's Avatar
Quick update:
Car was on a racepak dyno this past Saturday
Numbers:
424 TQ RW
410 HP RW
Builder says car should make around 440 RW with this combo but with a different muffler setup. I know it sounds like a stretch but I'm running the biggest muffler Billy Boat makes to make sound for laguna. Think RV muffler.
I'll be picking up the car this Friday from Grass Valley and will have it available for showing after.
1967 Nova
2018 Camaro ZL1 1LE
Old 10-28-2017, 12:46 PM
Try2paz's Avatar
1967 Nova
2018 Camaro ZL1 1LE
Old 11-15-2017, 10:13 AM
Try2paz's Avatar
To the top:
Forgot to mention the rear end.
looking to move the car this winter. I've put some light driving miles around town and the motor feels great and the trans is nice and tight after the rebuild.
1967 Nova
2018 Camaro ZL1 1LE
Old 05-08-2018, 07:46 PM
Try2paz's Avatar
TTT..Car will be at Goodguys June 2/3rd in Pleasanton. After that it goes up on E-Bay or Bring A trailer.
NEW PRICE!
1967 Nova
2018 Camaro ZL1 1LE
Old 05-09-2018, 05:35 PM
glassman's Avatar
glassman glassman is offline
NEW PRICE!
Why can't you just wait one year???? I know you want to keep it in town. trade for a lawn mower and a toolbox?
Mike
Old 05-10-2018, 06:06 AM
rushca01 rushca01 is offline
Beautiful car, we go nicely with my GT350. Too bad you’re 2000 miles away.
Old 05-10-2018, 08:43 AM
Try2paz's Avatar
Is the mower bag full of cash =)
business is good right live a little =)
1967 Nova
2018 Camaro ZL1 1LE
Closed Thread
