Old 10-10-2016, 12:05 PM
samckitt's Avatar
samckitt samckitt is offline
Default Which battery? Optima died.
I have had Optima batteries pretty much since car has been running, but it seems that if you don't drive it alot it seems to loose power & then if too low kills the battery. For the cost seems like they should last better than that. Anyone else see this too?
Scot
86 Monte SS
LS2/T56 Magnum
Old 10-10-2016, 01:22 PM
cpd004's Avatar
cpd004 cpd004 is offline
Same here. I gave up on Optima. Friends have had similar issues. I went with XS Power. So far so good after 5 years.
1971 Firebird
2017 SS
Old 10-10-2016, 03:29 PM
ilikeike's Avatar
ilikeike ilikeike is offline
I gave up on the Optima myself,after two in the boat and one in the truck went far too quickly in my opinion.
I'm on to Odyssey batteries now,
I pulled the 6 year old Odyssey out of my truck to use in my Camaro project last year just to test the electrical and fire it,but it's still going strong @ 7yrs old now.
Old 10-10-2016, 06:30 PM
slimjim's Avatar
slimjim slimjim is offline
+2 for XS power, I bought one 6 years ago, had it in 3 different cars, one of which sat around for 18months at one point and the engine started right up first crank
NC
streamline 68 camaro
Build Thread here
Old 10-13-2016, 08:01 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
I also got an Odyssey this past spring. Not one complaint! Would definitely recommend.
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 11-19-2016, 08:24 PM
gnx7's Avatar
gnx7 gnx7 is offline
Stay far away from Optima batteries. If they ever get fully discharged they are never the same. The company was sold a couple years ago and ever since the quality has gone in the toilet.
I run Odyssey PC925 batteries and they kick butt. 26lbs and plenty of CCA
Old 04-24-2018, 04:07 PM
ragz ragz is offline
Just my opinion..... if you gave me an Optima,i would not use it... had no luck with them.
Sent from my SM-G965W using Tapatalk
Old 04-25-2018, 08:15 AM
Panteracer's Avatar
Default Optima Battery
Anyone tried the new Antigravity batteries
They had one that was race car only and just
came out with a new one more driver car friendly just
no big amp stereos etc
I was thinking of getting one as they are 11.5 lbs vs
my 43 lb optima.. a good way to shave weight but
costly at $699
Bob
Old 04-26-2018, 03:44 PM
shelteredV's Avatar
shelteredV shelteredV is offline
Wow, that's way expensive! I can see it in a racecar where weight is critical, but a street car, nah. I always used Optima until the company sold and quality seemed to tank. Been using AGM's with good results since.
Old 04-27-2018, 03:05 PM
It's funny how this thread comes back here and elsewhere . . . there must be a continuing theme. For those fighting the weight of a battery in a car that actually gets used, like Bob's Pantera, consider what I did: Go to O'Reilly or Autozone and buy a 300 CCA quad/motorcycle battery (about $100.00). It's like 10 or 12 pounds; you can play hot potato with it. You just have to make a holder, which I did with some 16-gauge sheet (and some bolts and rivet nuts) I had leaning against a wall . . .
My Falcon has had one of these in it for some time now, and it never lost a charge through all the fun of getting the LS fired and running through the initial stages, which were many months and a couple track days ago. This is by no means an idea original to my car. Get creative, people. Check the pics of my crud to steal an idea that has worked quite nicely (with weight displacement benefits). For scale, that's only a 12" rotor.
