Old 09-28-2018, 03:02 PM
DOOM's Avatar
DOOM DOOM is offline
Default Any 5.7 toyota experts out there need help!!!
I'm rebuilding a 5.7 Toyota engine and need the proper procedure on how to set the timing chains ! I cannot find any clear explanation on how to do this! Please PM me any info if you can help me !
Mario
USCOLLISION
Old 09-28-2018, 03:23 PM
dhutton dhutton is offline
Several videos if you google this:
youtube 5.7 toyota timing chain marks
Apologies if you already looked at them,
Old 09-28-2018, 04:09 PM
DOOM's Avatar
Got all of that Don . Only problem is my chains don't line up I'm thinking the crank has to be move to set the chains . But nobody explains the procedure!
Mario
USCOLLISION
Old 09-28-2018, 04:46 PM
Ok, one last try.
https://www.toyoheadquarters.com/thr...arks-5-7l.330/
Old 09-29-2018, 04:29 AM
Sheck44's Avatar
Sheck44 Sheck44 is offline
Default 5.7
Mario ... my mechanic just rebuilt on of these and its a HUGE PITA
FYI ... One thing to know, I believe he said (found out after) there is a specific order/sequence that the rods go in or the crank will NOT turn freely
I can ask him about the chains
Steve
'Build it RIGHT the 2nd time'
69' SS X11 PRO-TOURING - SOLD
73' FJ40 LS - SOLD
1966 FJ40 R2.8 -SOLD
911 Hotrod - SOLD
2002 Gated 360
Next up - "Killer Piggy"
67' Camaro - Take-Over'
Old 09-29-2018, 09:11 AM
How many miles on it prior to rebuild?
Old 10-02-2018, 12:44 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I've done lots of those, used to remove those cam gears with the timing covers on but hard to explain with just words, the left and right bank cam gears are the same but each side uses different marks. You also gotta push the hydraulic tensioner back and put a pin in it to hold it retracted, this gives you enough slack in the chain to get it on, once the chain is on you pull the pin on the tensioner.
The cams sit in a kind of relaxed state when in the right place, then the crank has to be obviously in the proper relation to them to put the chain on, so you might have to rotate the crank some. Just be careful, you don't want a piston to hit an open valve (duh!). Can you post any pics of its current state?
Erik
69 Camaro
Old 10-04-2018, 10:04 AM
DOOM's Avatar
I think I figured it out but I'm still not 100% sure I got it right I'll put up some picks . Thank you! I offered a Toyota Mechanic $200 to stop over to see If I have it right . Never happened
Mario
USCOLLISION
