Old 10-14-2015, 09:59 AM
GPR's Avatar
GPR GPR is offline
Default 1978 Mustang II restomod
I took this in trade a few years ago toward some of the labor on restoring a Mustang. This is what we are starting with. The hood scoop has to go. I have always liked the Mustang II and I plan on making this my driver.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 10-14-2015, 10:05 AM
GPR's Avatar
GPR GPR is offline
I'm not sure what they were thinking or what they used to cut this hole in the hood.
After Brian worked on it
The hood was sanded down to bare metal and all the old scoop holes welded.
It looked good before it was primed but it needs a lot of work
After a little block sanding and bodywork
I plan on using the Mach 1 scoop and once that comes in I will bolt it on and finish the bodywork. At this time the hood is low in front of the hole but the scoop should draw that up.
I sprayed a couple of coats of epoxy to seal the bodywork.
A had enough Slick Sand polyester primer for a couple of coats
Block sanded with 80 and found one low spot that required a little filler
Two coats of SPI Turbo primer
The hood required a lot of work but I'm happy with it now.
Rusty Gillis
Port Richey Fl
Old 10-14-2015, 10:08 AM
GPR's Avatar
GPR GPR is offline
We have a new problem. This was filled with bondo. I had not planned on taking out the gas tank.
The rust was cut out.
Eleanor gas filler kit from Mustangs to Fear was welded in place. A gas filler neck from a 1968 Mustang was also used.
Billet gas cap from Mustangs Unlimited
Rusty Gillis
Port Richey Fl
Old 10-14-2015, 10:12 AM
GPR's Avatar
GPR GPR is offline
I wanted a cleaner looking taillight panel so the Ford holes were welded and ground down
The bodywork is finished on the taillight panel
Scottrods rear bumper fits great. The original bumper brackets were cut off and two holes were drilled in the trunk for a test fit. Add a few more bolts inside the trunk and a couple on each quarter and your done.
Rusty Gillis
Port Richey Fl
Old 10-14-2015, 12:33 PM
GPR's Avatar
GPR GPR is offline
We found a 8" rear from a 1965 Mustang. The spring perches are a little wider on the rear but we made it fit. I ordered a 1" lowering kit.
I installed a Rod & Custom front suspension in my 1968 Coupe and upgraded to Baer brakes so I used the original ones that came with the kit on the II.
The front fiberglass bumper was to wide and shaped wrong at the bottom
I cut and taped a piece of aluminum
Added three layers of fiberglass mat
Removed the aluminum
Still needs more work
When I'm finished the valance and bumper will be one piece.
I added 3 layers of fiberglass mat on each end and now all I have to do is fit the center piece and a lot of bodywork and I will have a one piece bumper and valance!!
Test fitting the one piece bumper and valance
I still have a little work to do to get it lined up to the fenders
Rusty Gillis
Port Richey Fl
Old 10-14-2015, 08:21 PM
awr68's Avatar
awr68 awr68 is offline
Nice Fab/Body work!
Tony
'68 Camaro
Old 10-15-2015, 04:21 PM
Wow what a differance already. Nice job.
Old 10-16-2015, 07:16 AM
GPR's Avatar
GPR GPR is offline
We had a few rust holes in the floor that were cut out and new metal added.
Floor was sanded and epoxy primed black
Because this has a T-top we are going to add subframe connectors and a roll bar from S&W. The roll bar was sanded and epoxy primed.
Rusty Gillis
Port Richey Fl
Old 10-16-2015, 07:26 AM
GPR's Avatar
GPR GPR is offline
The major bodywork is finished
Two coats of SPI epoxy
Block sanded and a little more bodywork
More epoxy
I block sanded again and sprayed white epoxy. I have decided on a color SPI Orange. It is a little darker in person
Rusty Gillis
Port Richey Fl
Old 10-16-2015, 09:36 AM
Nice color choice, Rusty! Good luck with the build.
