Old 08-31-2006, 08:10 AM
tndude tndude is offline
Default Rotisserie
I'm building another one so this one is up for sale. Its on ebay.
Happy bidding.
Old 08-31-2006, 10:49 AM
68protouring454's Avatar
looks good, but the connecting pipe that connects the mtwo end uprights, needs to be way tighter, there is alot of slop and even though you have the wedge bolt in there the pipe will still hinge inside, you do not know this cause you never put a car onit, the slop will make the end uprights lean in big time, i only had 1/4 slop with a stop screw and mine leaned in alot, you need to tack some spacers in the female pipes to keep the male peice from sliding around
by leaning in i mean the uprights will want to fold in towarsds the car on each end
jake
Old 08-31-2006, 01:01 PM
Will do. Sounds like an easy fix. Thanks Jake.
Old 08-31-2006, 02:21 PM
weld spacers on the the front and back of the female tubes, that way the pipe cannot, pivot in the tube
jake
Old 09-04-2006, 07:01 AM
bttt .
Old 09-08-2006, 05:25 PM
one last time....ttt.
